Can I adapt to a cast iron tee without cutting? Replacing a lead bend.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by stanman37, Nov 17, 2009.
  1. stanman37
    stanman37 New Member
    Nov 17, 2009
    tech in telecommunications
    New Jersey
    I have been asked to help a friend who has a old toilet lead bend that has been repaired so much using epoxy putty that you can't see it anymore. It goes into a old cast iron sewer stack via a tee (I believe it's called). I would like to adapt plastic to the cast iron tee without cutting and wonder if there is a fitting (heard of fernco but can't find anything specific) that would actually adapt to the collar of the tee if I chop/melt the lead out. I researched about snap-cutting a section of the stack out and replacing it with a fernco tee but there is a gas pipe tight to the right of the pipe and a lath and plaster wall directly behind. Don't think I can get the chain around it and would rather keep it intact if I can since it doesn't seem to be deteriorated. I'm attaching a picture - hope it comes out. My main concern is that if I can adapt to the outside of the existing cast tee - what would keep the waste from getting caught on the inside - or would I push the new 3 or 4" pvc or abs deep through the rubber coupling so the waste doesn't get a chance to get hung up on it?
  2. Terry
    Aug 17, 2004
    [​IMG]
    I normally just pull the lead out of the cast iron tee, and use a 4x3 flush bush into a insert rubber pipe donut.
    [​IMG]
  4. stanman37
    Nov 17, 2009
    New Jersey
    Well, thank you very much! That is spectacular. If you don't mind some more information.. How far do you insert the abs through the bushing and is it a special type of cement to join the two or just regular abs cement?
  5. hj
    bushing
    You insert the PVC all the way to the stop in the bushing, and it does not get glued in.
  6. Marty53
    Marty53 New Member
    Apr 10, 2009
    New York
    you can also get a fernco fitting that goes over the whole hub of the cast iron tee.
  7. Doherty Plumbing
    Doherty Plumbing Journeyman & Gas Fitter
    Jun 22, 2009
    Red Seal Journeyman Plumber & Licensed Gas Fitter
    Penticton, BC
    Don't do this! You will be creating a lip inside the pipe from the hub of the cast iron fitting. This eventually gather enough stuff to plug your line. Or atleast has the potential to.
    Terry's example is a perfect example of how to do it.
  8. stanman37
    Nov 17, 2009
    New Jersey
    That was the only option I thought I had in the beginning and my concern exactly and the reason for joining this forum. Didn't know I could use a "donut" or "multi-tite pipe gasket" as more research showed. So thank you all for your input. I believe I'll be good with that option.
  9. stanman37
    Nov 17, 2009
    New Jersey
    As long as you folks are friendly, and this is an active forum, I'll post another picture, further down the line of the lead bend and run my thoughts on that.. This shot is of the old drain pipe which later tees off on it's own to receive waste water from the sink and tub. It feeds into the lead bend as it turns up toward the toilet - through the concrete/cement floor (which we'll probably be best off redoing also - the floor - but anyway)...
    I suppose to incorporate this drain system into the same cast iron tee, I'd use a donut as suggested and come out with a short piece of plastic (abs or pvc) to another tee turned almost sideways... (I'm thinking a 3" x 3" x 2") then put the toilet fittings into the 3" straight part and bring a 2" drain into the tee part... or do they still make and allow by code, a similar fitting as shown in the lead - where a 2" drain combines with a 3" bend from the toilet?
  10. Plumber Jim
    Plumber Jim Member
    Mar 29, 2008
    Use a 90 with a 1 1/2" on the heel.
    [​IMG]
    glue in a small piece of pipe then use a fernco to connect from the plastic to the old lead.
  11. stanman37
    Nov 17, 2009
    New Jersey
    Exquisite! You guys are great!
  12. hj
    connection
    They do NOT make a Fernco that "goes over the hub". There are Ferncos which WILL fit over the hub, but that is not what they were made for, nor is it an approved use for them.
  13. tjbaudio
    tjbaudio Sound and Light Suppervisor for a School District
    Dec 6, 2005
    sound and light suppervisor for a school district
    Wisconsin
    BTW there are many sizes of these donuts. It took me 2 trys to get the right size. Clean the hub well (I used a side grinder with a wire wheel.) The donut will need to be hammered in place per the instructions.
    Also the fernco to the sink pipe needs to be banded.
Similar Threads: adapt cast
Plumbing Forum, Professional & DIY Advice What is a cast iron adaptor fitting? Jan 21, 2014
Plumbing Forum, Professional & DIY Advice Adapt Cast Iron Main Cleanout -- DW Aug 15, 2011
Plumbing Forum, Professional & DIY Advice Faucet adaptor sizing Oct 24, 2016
Plumbing Forum, Professional & DIY Advice Reusing 1" flare adapter Sep 3, 2016
Plumbing Forum, Professional & DIY Advice Looking for 3-inch ABS no-hub adapters in Seattle area Jun 22, 2016
