breaker size for 12 gauge wire
Discussion in 'Electrical Forum discussion & Blog' started by whoazone, Jul 15, 2008.
  1. whoazone
    whoazone New Member
    Jul 15, 2008
    What is the largest breaker I should use on 12 gauge wire? How about 14 guage wire?
  2. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    #12=20 amp breaker
    #14=15 amp breaker
  4. whoazone
    whoazone New Member
    Jul 15, 2008
    Can 10 gauge wire handle a 30 amp breaker?
  5. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Basically, yes.
  6. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    30 amp breaker with 10g wire is usually what is used for an electric water heater.
    Mike
  7. hj
    wires
    Are you asking for a specific appliation, or just fishing for information?
  8. pudge565
    pudge565 New Member
    Dec 30, 2007
    If using ROMEX® those answers are correct but if its not ROMEX® it depends on the wire insulation type and if it needs to be derated.
  9. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    What are you talking about? Try reading 240.4(D)
  10. pudge565
    pudge565 New Member
    Dec 30, 2007
    Yes my bad I don't know what I was thinking maybe flexible cords?
  11. Johnny C
    Johnny C Electrician
    Oct 19, 2008
    Elect Teacher, Consultant, Seminar Presenter, Elec
    Mass. & now Virginia Beach, VA
    Breaker size for # 12 wire
    You have not specified what type load and what type overcurrent protection is provided ie. (circuit breaker or fuse) the #12 conductor is supplying. If the circuit is supplying a motor load, the NEC allows a CB or Fuse rated greater than the conductor ampacity.
Similar Threads: breaker size
Electrical Forum discussion & Blog What size wire for a 230 volt 20 amp breaker? Jun 14, 2015
Electrical Forum discussion & Blog Breaker and wire size for pool heat pump - MCA, wire and breaker size. Feb 28, 2014
Electrical Forum discussion & Blog oversized circuit breaker question Nov 4, 2011
Electrical Forum discussion & Blog Sizing Kitchen Range Breaker Size & Wire Gauge Apr 12, 2011
Electrical Forum discussion & Blog Installing an AFCI breaker Jan 5, 2017
