Boiler pipes and electric baseboard heat
Discussion in 'Boiler Forum' started by Stoytam, Jun 5, 2013.
  1. Stoytam
    Stoytam New Member
    Jun 5, 2013
    MD
    My husband and I are looking at an aprtment on the Upper West SIde of NYC. It is being completely renovated. It is a WW2 era building made of stone. THe landlord has said that he is getting rid of the radiators and replacing them with baseboard heating. He says that since the boiler pipes are still in the walls and will be hot. He has added baseboard heating as a "back-up" for anyone who wants additional heat - which the tenant would pay for themselves. Can boiler pipes in the walls provide any warmth to an apartment without a radiator? We have not signed the lease yet....pls respond as soon as possible. We are freaked out about signing this lease and being stuck with a HUGE heating bill. Thanks!
  2. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    Yes, steam pipes embedded in walls have a lot of surface area and can put a lot of heat into the space, but it's at an uncontrolled rate. Using electric baseboard to heat the place is insanely expensive at NYC's electricity pricing to operate in comparison to a central gas boiler, even at the atrocious efficiency of some of those systems. The landlord saves a lot of money by only partially heating your space, but you make up the difference with the most expensive heat possible.
    And unless the landlord will stipulate in writing that the pipes will always be hot when it's below 60F outside, the baseboard could be covering 100% of the heating load.
    If the landlord were installing a ductless air source mini-split heat pump instead of baseboard it might be more reasonable for the tenant, since the efficiency of mini-splits is high in both heating and cooling mode (it's 2x as efficient as a window air conditioner, and 10x quieter), but that's a lot more expensive to install than electric baseboard.
Similar Threads: Boiler pipes
Boiler Forum Boiler Pipes hot when heat has been off for months? Boiler used for DHW. Nov 16, 2011
Boiler Forum New Boiler - pipes keep leaking...help Oct 4, 2010
Boiler Forum Insulating BoilerCopper Pipes Feb 4, 2010
Boiler Forum Boiler firing without call for heat on cold start Sunday at 6:17 PM
Boiler Forum Weil McClain cga6pidn boiler Mar 17, 2017
