Best toilet paper that doesn't clog & easily dissolves?
Pietroone
Philadelphia
Hi, have had two recent clogs many feet down the pipe after the Toto Drake. Plumber had to remove toilet and run a snake and said he hit toilet paper. This issue in part may be the Northern toilet paper. Any specific toilet papers that you can recommend? Looked on Consumer Reports and it seems their recommendations for toilet papers are either no longer made or with poor user reviews. Appreciate any currently available recommendations.
Other though I have is the flapper valve is closing to quickly so not getting a lot of volume during the flush. Using the Korky 2021BP G-Max replacement Flapper. Doesn't appear to be adjustable so that flapper will stay up rather than close almost right away. Any thoughts on this?
Thanks
https://terrylove.com/forums/index.php?threads/problem-with-toilet-paper-toilet-paper-poll.1661/
Good Housekeeping Institute's Textiles Lab 2005
Brand Dissolvency Time in Seconds
(lowest is best)
MD 2-Ply, 9
Coronet 2-Ply, 12
Angel Soft 2-Ply, 12
Scott 1-Ply, 17
Soft 'N Gentle 1-Ply, 18
Soft Weve 1-Ply, 20
Marcal 1-Ply, 20
Soft 'N Gentle 2-Ply, 21
Seventh Generation 2-Ply, 21
Quilted Northern Super 2-Ply, 69
Charmin Ultra 2-Ply, 77
Cottonelle 1-Ply, 96
Charmin 2-Ply, 180
Also, Fluidmaster makes a good universal 3" flapper that will adjust for different water usage.
While a different TP may help, it's likely that there's an issue in the plumbing pipes. That could be improper slope, a belly, a partial collapse, and maybe some other thing I haven't mentioned.
Pietroone
Philadelphia
(lowest is best)
MD 2-Ply, 9
Coronet 2-Ply, 12
Scott 1-Ply, 17
Soft Weve 1-Ply, 20
Marcal 1-Ply, 20
Charmin 2-Ply, 180
Thanks Terry ... your site and service is second to none.
I walked into a home the other day and the pet had shredded the paper in the bathroom.
Which way do you hang your paper?
Some pet owners do it this way, my critters don't play with mine, so I have mine outward.
If your pet tries to roll it, smash the roll so that they don't spin easily.
I go out also, but in is good if the out-paper would dangle onto your leg.
Unless the roll is low, I don't feel strongly on this.
