JB412
- Messages
- 24
- Reaction score
- 0
- Points
- 1
Hi all,
I'm hoping for some advice that will save me much time and effort. I removed a vanity from an upstairs bathroom in hopes of replacing it with a pedestol sink. In setting up the new sink I discovered that the existing drain pipe was about an inch too long from the wall, and needed to be cut back. While I was out getting a few parts, a friend of mine (perhaps ex-friend now) dropped by the house and my wife told him of the problem. Well, he decided to "help" me and used a pipe wrench attempting to unscrew the ABS drain pipe! I now have a deformed piece of ABS pipe that I now have to somehow cement a fitting to in order to install my drain. The drain in the wall has a tee which is used as a common drain to an adjacent bathroom vanity. I'm trying to avoid having to cut the wall open and dismantle the adjacent bathroom's drain to try to replace the tee if at all possible. I am able to force a female fitting over the deformed pipe but I'm worried that the gap at the flats (see pics below - flats at 2 o'clock and 8 o'clock) won't seal. I was also thinking of putting on a ton of glue/cement in thos areas and sealing around the end of the fitting with something (??). Any advice would be appreciated. (The gap at the flats appear to be about 1/8" in the fitting).
Thanks for any help!
Jerry
Jerry
