Bad Well Case
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by CR500, Jan 5, 2009.
  1. CR500
    CR500 New Member
    Jan 5, 2009
    I have a three inch well, its old, water is around 30 feet down. Replaced foot valve a couple of years ago and it still bled down so pump ran every five minutes or so. This last week or so pump was constantly cycling and finally lost prime again so I pulled drop pipe out and found lots of mud and small pebbles around packer.
    Well guys wont make it a 2" for me. I want to drop 2" inside the 3" then put a new 2" packer and so on. Don't know much about wells but what I have read today. Cant find any real info on doing this.
    Can I use pvc inside the 3" existing or do I need to use galvanized? Can I even do this? I don't see a good reason not to other than local codes.
    Any help will be greatly appreciated.
  2. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    A waste of time!
    Installing a 2" liner inside of a 3" casing is a poor excuse for a band-aid.
    More than likely there is a hole in the 3" casing somewhere and to install a 2" liner (pvc or galvanized) will not prevent the mud. The mud will travel down between the two pipes and come up in the bottom of the 2".
    Your driller was right, best bet is a new well!
  4. CR500
    CR500 New Member
    Jan 5, 2009
    Talked to a different well guy and he got it done this morning. He installed packers top and bottom between the 2" and 3" and went 15' beyond where the old drop pipe stopped with the 2" pipe. Old hole in case has nothing to do with the setup now. Water was clean after an hour or so and pressure is good.
    Poor excuse for a band aid? I don't have the kind of money its going to take for a new well. Could it develop another hole farther down later? Sure, but $700 is a lot easier to do than $6000. The propane guy was just here and put $935 in the tank. Didn't work for the last two weeks because of weather and holidays then had to miss more because of this. I will run it until it quits. Thanks for your help.
  5. johncook
    johncook New Member
    Dec 12, 2010
    brentwood ca.
    funny that the first answer from all these well pro's is 'put in a new well'
  6. justwater
    justwater Well Drilling/Service
    May 13, 2010
    FL/GA
    nothing wrong with a patch like that. especially if thats all it cost u. just needed someone who knew what they were doing and is familiar with how the wells are done in ur area, which apparently u found. Good for you!!
  7. ballvalve
    Dec 28, 2009
    northfork, california
    Good job cr500. Doctors always want to operate when a much safer and simpler solution is at hand. Shop around and ask around about drillers.
Similar Threads: Case
Pumps and Tanks Well Forum & Blog. Water is life. Any experience with plastic case pumps like Onga JM100? Oct 31, 2015
Pumps and Tanks Well Forum & Blog. Water is life. It's dead Jim. Well, 940' cased, 2hp at 600' 1.25" PVC pipe. Replacement Advice and $WAG please. Aug 19, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Do I need a well-point for preexisting cased well? Setup questions, PVC alternatives? Jul 19, 2012
Pumps and Tanks Well Forum & Blog. Water is life. help.How to re-case a well ? Dec 13, 2010
Pumps and Tanks Well Forum & Blog. Water is life. Starting up a 25 year old "virgin" 2'' cased well Jan 28, 2010
