efinley
OK guys, you've helped me a bunch in figuring out what kind of system I need for my new well and storage tank. I'm nearly done trenching and wiring but in the mean time I've got wire and pipe running above ground as a temporary solution.
The problem is that on Saturday after finally finishing the trenching to the wellhead, the last 60' were solid rock so I was digging it with a rock bucket. Probably not related...
So after digging all day I go in to take a shower and there's no water! The pump and well have been working fine for 3 weeks now (just started using them) but now getting water is sporadic. It is possible the well isn't recharging and the pumptec box is doing what it is supposed to, but yesterday we used maybe 100 gallons of water total before the QD kicked in.
I have a Goulds 5GS10 1 HP pump set at 380' with a hypothetical static water level of 80'.
When the pump is pumping it is pulling 9.6 amps off one leg of the supply.
After the QD kicked in I hooked the ammeter back up and flipper the breaker on. The current would oscillate between 9.3 and 10.4A and then in under a minute the current went to 0 as the QD kicked in again. I know the QD kicked in because I still had 240V going to the QD box.
I can't find my pump in the Goulds tables but based on other 1 HP pumps it seems my current is a little high. What do you guys think?
BTW I'll mention this because of another thread I read (I promise I tried to do my homework before posting), this pump was set about 3 years ago, we just got around to using it now that the pump on our old water system died. So it sat unused for 3 years with only occasional use as I would haul a generator out just to mess with it.
-Eric
-Eric
