Backerboard questions for cultured marble shower
omo
I ordered my cultured marble shower today and want to make sure all my ducks are in a row before it arrives. I have a few questions about backerboard.
1.) Is durock sufficient backing material. I had read somewhere that it may not be strong enough by itself and should be used in conjunction with greenboard for strength. Is that so?
2.) Each wall of my shower will be covered by one solid cultured marble panel. Is a vapor barrier needed?
3.) I'm still not clear on what material I should use to imbed the fiberglass tape when I tape the seams of the durock. I will need to make a smooth surface. I had read to use thin set mortar, but it seems to me that if I used thin set I wouldn't have a flat surface. What am I missing?
Thanks in advance for your advice. This forum is a lifesaver.
Can you go to the manufacturer's website and download the installation instructions? That would be best; otherwise, you'll get generalities.
1/2" durrock is strong enough on a wall to support a tiled wall, I don't see why it wouldn't work under the panel. Now, if you really need it is another story all by itself.
The durrock (or any other brand of cbu) is NOT waterproof, it is just unaffected by moisture. My guess is that the manufacturer will probably request a vapor barrier behind the panels - simple plastic sheeting will work. Now, since the panels are water and moisture proof (except for any failed seams), they may not even require anything.
When using cbu as a tile substrate (which is what it is designed for), you use alkali resistant fiberglass mesh tape and embed it into thinset. It is easiest if you do this while tiling, otherwise you usually end up with speedbumps that make tiling (or putting up a panel) difficult, since the surface ends up with a hump at the seam. The mesh tape and the thinset at the joint is there, not like doing a drywall seam, to create a monolithic surface, not a pretty paintable surface like with drywall. Since you won't have tile and grout to crack, my guess is that if they want cbu up on the walls, you won't have to do anything with the seams. I'd still put up a vapor barrier behind it and bring it down to the lip of the pan. My unprofessional opinion.
The manufacturer's instructions always trump opinions if you want a warranty.
Also note, it may offer setting the pan without a mortar bed as an option...don't take it - use it and you will increase the life and your satisfaction with the install. Make absolutely sure that it is sitting level in both directions, or you will have problems with the walls and draining, too. That is another reason to use mortar under it - you can smush it down into the stuff, it is fully supported, and you can get it level.
Good luck.
omo
Thanks for your help, Jim. I am bothering the forum with these questions because the manufacturer's instructions are very vague. Nothing is said about vapor barriers or what type of backer is recommended. I have even called the manufacturer with questions and have not been given satisfactory answers. So I really appreciate the help that you and others on this forum have to offer.
To follow up on your reply, the shower pan that I have ordered does not have a tiling flange. If I put up a vapor barrier, where would I direct the bottom of the vapor barrier? I know normally the bottom of the vapor barrier would go over the flange and end there. Without a flange, should I just cut the vapor barrier about half an inch above the shower base and leave it hanging? I was actually hoping that I wouldn't need to mess with a vapor barrier at all since a cultured marble panel shouldn't be porous.
As far as the seams, I guess I will leave them unfinished. Makes things easier for me, as long as that is a safe practice to follow.
Jimbo
San Diego, CA
They make a waterproof joint compound to use with the fiberglas tape. This tape joint ( seams and corners) doesn't have to be glass-smooth like wallboard. You are adding a thickness of mortar or adhesive which more than covers any uneveness at a seam.
I don't see how you have a shower pan without a flange. Doesn't sound like a pan. This is a recipe for a leak.
Sulconst2
old bridge nj
i would mesh tape with thinset then after it dries skim coat the entire surface with thinset. plus were the cbu hits the pan use a high quality caulk. then again for the panel.
jimbo 1000th post congrats!! :D
Khayes
Alpharetta, GA.
I just had a cultured marble shower surround installed. I was told by the manufacturer, no need for backer board. We just used greenboard fastened directly to the studs. No vapor barrier. The shower pan itself resembles a box with no top, that is the sides extended up the wall about 9 inches. The cultured marble panels where 3/8 inch thick and were siliconed to the green board and extended over the pan sides and rested on the bottom of the pan. All joints were siliconed. It looks great!
The installers around here use greenboard too.
The cultured marble is a good product.
Designers Marble in Woodinville
omo
Do you think greenboard is superior to Durock for this application?
PEW
DIY Senior Member
Cheaper and easier to work with.
Being you are covering it with a product which is impervious to water, greenboard is more than enough. If you were looking for additional insulation you could consider Wedi board, but it is rather expensive.
Paul
Chassis
Engineer
SE Pennsylvania
omo, if you would like additional advice on this question, try posting your question in the Tile Forum/Advice Board at www.johnbridge.com. Good site focusing mainly on tile and stone issues, but showers are a large proportion of the discussion topics.
V
veronashowers
Guest
Shower Remodels
Hi,
I would like to share all about Luxury Bath.
Verona Showers strives to design and manufacture the finest and most innovative bath remodelling products in the industry.
www.veronashowers.com
13912 Park Center Road, Herndon, VA 20171
Phone: (703) 435-5557
Fax: (703) 435-5522
TWEAK
Bay Area CA
The cultured marble is waterproof. But the joints are not.
It's similar to tile. The water that gets behind tile gets through the grout lines, not the tile. Yes there is far more linear feet of grout than you will have with your cultured marlble, but don't ignore the joints. The silicone or polyurethane sealer the installer will use in the corner is good when new. It doesn't last forever.
In my experience, I do not like greenboard in showers or tub surrounds. It is fine for the rest of the bathroom where humidity is high but in "wet areas" I would never use greenboard. If your caulk starts to leak it will get very wet and turn to mush.
Cement board could be used, but it's not the best method. Cement board is also not waterproof. Put a garden hose on a piece of Wonderboard and you will see this very clearly. If you want to use it, put down drywall first, then a vapor barrier of 6 mil polyethylene. Some people use 15# felt paper, but I strongly believe that 6 mil or heavier poly will last forever, the paper will not. Then hang your cement board. You can use alkali resistant mesh tape and thinset at the joints. If you REALLY want a watertight job, put some P&L polyurethane door and window sealer (not silicone) one each cement board screw. Then hang your cultured marble.
The problem with the above method is that water will eventually get through the seams unless you re-caulk with 100% silicone or polyurethane every year or two. If your seams start to leak, the cement board behind will get saturated and you can definitely grow mold in cementboard. That's why the above is not the best method.
The most bulletproof, long-term thing thing you could do IMO would be regular sheetrock. Do not tape or mud the seams. Then install one layer of Schluter Kerdi over the sheetrock, exactly like a tile job, according to Schluter's instructions. You apply the Kerdi with unmodified thinset, mixed very loose. The Kerdi is pricey, it will cost you about $250-400 depending on the size of your shower. But that is cheap compared to what your spending on the cultured marble. The Kerdi IS totally waterproof and vapor proof. Use Kerdifix sealant around all the penetrations and where the Kerdi goes up over the lip of the pan. Kerdifix is over $20 for a caulking gun size tube, but you only need one. Then put up your cultured marble walls with thinset directly to the Kerdi... maybe two screws through to the studs located up high (the cultured marble can be filled so that you will never see the screws).
Most tile places sell Kerdi in full rolls, which is very expensive. You can order just what you need from "tile experts" on line.
The thing about the Kerdi method is that the if any water gets through the caulk joints, the first thing it sees is the Kerdi membrane -- not cement board or greenboard which it will saturate. You don't want anything that holds water behind the cultured marble.
Some may think this is overkill but if it's your house and if you've ever had water damage you will probably want the best solution. Good luck!
All cultured mable in the Seattle area is installed over greenboard.
The marble panels are water tight.
The joints are made with Silicone.
The stuff looks great 30 years later.
TWEAK is guessing on his answer.
Don't make it harder then it needs to be.
The reason for greenboard, the glue sticks to it.
You don't want the marble panels falling down.
The water never gets past the marble and silicone.
TWEAK
Bay Area CA
Terry, I agree that your solution may be fine IF the silicone holds. Have you ever seen caulk on a tile install that needs to be re-done? This is no different.
If there is a bit of dust, skin oil or other surface contamination the material the sealer won't hold as it should. Or if the installer doesn't get it down perfectly. The homeowner will not know about the problem.
If the house settling , and normal expansion and contraction, the shower can move a bit and the joints start to seep water. The homeowner will not know about the problem.
If the escutcheon around the valve lets a bit of water past, the greenboard will turn to mush. The homeowner will not know about the problem.
Until it is too late.
I am not guessing, I have done this. Before I did it I was in touch with Schluter Systems, asking about how to insure water couldn't get through the corner seams. This was their recommendation for an absolutely bulletproof installation.
The panels will not fall down. I suggested screws at the top into the studs -- better than glue. You can fill the screw holes easily on cultured marble and never see it.
People said the the same thing about tile installed directly over greenboard. Now it's no longer approved because years later many people had water damage.
For 1/2 a day of effort and a few hundred bucks of Kerdi - which is easy to hang - you can have an installation that you will never have to worry about.
Judgement call.
Chefwong
District of Columbia
I agree with Tweak with one exception. CBU in any wet application. If you want to take it to another level, CBU with Kerdin.
I would not do regular sheetrock with Kerdi . If a PRO did it, I would consider it.
Sheetrock with Kerdi - the variable I see for a DIY is making sure you are sealing the areas where the valve stems, stubs, etc don't penetrate and make the wallboard underneath soft..
TWEAK
Bay Area CA
I originally thought CBU with Kerdi as well but Schluter talked me out of it. They are adamant that sheetrock is the way to go. They say if done carefully, no water will get behing the Kerdi. I took their advice, they should know how best to use their stuff. I was very, very careful to get it sealed up, overlapped the Kerdi more than they recommend, etc.
As far as the penetrations go - I completely agree with you, this is a big concern. What I did was lap the kerdi around and penetration in the sheetrock with liberal use of the kerdifix sealer. My escutcheon/trim for the valve was pretty well sealed to the valve -- but it did have the typical cheesy foam gasket, held on to the back side of the escutcheon with double stick tape - for sealing up against the wall. I removed the gasket, cleaned off the double-stick crap (rolls off easily), coated the gasket with liberal amount of silicone and re-installed. I have an access panel for the plumbing behind the wet wall (it's in the garage for this bathroom - easy!) so I could confirm "no leaks".
I've since learned that Schluter does make some kerdi "fittings" with rubber seals for the penetrations. I would like to take a look at these to see if they would help, but didn't know about them at the time. The Schluter tech I spoke with didn't mention them, he just advised sealing it all carefully with the kerdifix.
Water behind the shower is bad news. I've had a slow leak that was totally unnoticed and ended up causing me to put an entire bathroom into a dumpster, build temp walls to allow me to rebuild destroyed load bearing walls, jack up sag in the roof due to the rotten load bearing wall, tear out entire subfloor and floor joists, etc..... so IMO there's no such thing as overkill when it comes to a shower.
Chefwong
One more note after re-reading the OP.
If you decide to use a vapor barrier, use CBU and then go to town.
If you decide to use CBU straight, then do CBU with Kerdi (my 1st choice)
Don't do both - Vapor Barrier, CBU, Kerdi.
You don't want to create a ~sandiwich~
I have never spoken to Schulter myself. I have spent as much time as needed digesting info from tile pros and tile pros generally prefer CBU over other bases. They will even go far to say the latter stuff like the hardie board, etc they strongly recommend to not use in Wet Applications and go with CBU if you can.
And yes, I do think a SUCCESSFUL Sheetrock/Kerdi can be done, I just think the variable where there penetrations, CBU would probably work much better in mitigating the water permeation issue...
TWEAK
Bay Area CA
Good call on the "sandwich". That would not be good. I imagine some people would make that mistake, assuming that if one vapor barrier is good, two would be twice as good!
As I see it, the bottom line is, when it comes to wet areas we should all do what we believe is the best installation possible. And the one that lets us sleep best. Kerdi is so easy, there is really no reason not to use it or something like it. If you are more comfortable with CBU, use it - it will be fine. No way though, that I would go with just greenboard in *my* home... seen that up close, wasn't pretty.
Pitt
Louisiana
Cultured Marbel Shower Pan
- I agree with everything TWEAK said. I have the same type of cultured marble pan originally mention above. My pan does not have a lip or flange. It is a solid base all in one pan. No-caulk drain mounts directly to it. I experienced the deteriorated sealant issue mentioned and subsequent leak.
- I am currently repairing and I will say from what I observed, you should never use any kind of drywall and Sheetrock behind a cultured marble panel (appearance is it is used for ease of installation not durability). Once it becomes wet it is useless and will start to mildew and has the potential for mold growth if not caught in time. The moisture barrier in this case will be useless as the panel gets wet from the front.
- One of the newer cement boards with a water tight sealant seams to be the best way to go for durability. I am no expert. I put a liner under my pan to make up for the no lip issue which creates a 6" lip all amount the pan. I will seal between the liner lip and the base with silicone. Then cement board will go up resting inside the lip and sealed to base with silicone followed by cultured marble panel sealed with silicone. Based on what I saw when I removed everything plus what I've read in forums, I'm convinced this is the best route to go for my shower.
