Johnnie_Rocket
My first post here... I used this site as a lurker to research a replacement toilet for a bathroom remodel. I learned a lot so I thought I'd give a little back by posting my experience with the American Standard Compact Cadet 3 Elongated Bowl. I searched quite a bit for info on this model but couldn't find much. In fact it is not even mentioned on the AS web site. I discovered that it was released some time in May 07. Maybe they just don't know how to update their wen site very well.
Anyway, I was forced to replace the tile in my guest bathroom because the builder apparently did not know how to use thin set and all the tiles popped off the slab which made them very easy to remove. I wanted to use the project as an excuse to replace the builders toilet with a nicer model and hopefully an EL bowl. Unfortunately space was kind of tight and a normal EL would sit out a few inches more into the door swing. I stumbled across this toilet at my local home store and after researching I decided to buy it. It received good ratings on the MaP ratings (1,000g of yummy soy paste) but I believe this was the "new" test material. The original "Cadet" apparently did not work as well as the new "Cadet 3" so if you are looking for a Cadet make sure you buy the "Cadet 3" which has a larger 3" flapper size vice the older 2".
I'm not a plumber but I've installed a few toilets on various projects. So I thought I'd post a novice's experience installing this toilet. A pro might do things differently but this is how I did it.
Cutting to the chase.... the compact design of this toilet does indeed allow you to install an EL bowl in the space of most Round bowls. The toilet works well and is quiet and seems to flush efficiently. It is a major step up from the builders special in both looks and performance. The tank mechanics seem to be of good quality, but the bowl suffered from warping which needed shims to sit flat. I had seen this was a common problem and had toilet shims on hand. But in the end I am very happy with this toilet and felt the price was decent. It doesn't have many "miles" on it so I don't know how the long term durability will be, but the technology in the tank is the "standard" flapper type which I can easily service myself assuming I can find the larger 3" flapper. I've read of some Champion owners who have a hard time getting parts.
So on to the "step-by-step" of my install. I will probably check back in here to see if there are any questions, but seeing as how I don't often shop for toilets I may not keep track of this thread for a long time. I hope someone finds this useful. I realize there are a lot of pros on here and hopefully they will chime in, but this is aimed at potential home buyers and DIY'ers.
For the Compact Cadet 3, you must get the matching compact bowl and tank. The compact tank is narrower and taller than a regular Cadet 3 which allows it to be squeezed length wise. I assume the back end of the bowl is also a little shorter than normal to match the tank. Notice the label says "Cadet3 Flush Right" which you might think means the tank flushes on the right, but it is really a marketing name "Flush Right" vice "Flush Wrong"... kind of a confusing name. The tank flushes on the left like most tanks.
