Are PVC unions allowed in a kitchen sink drain line?
cab1960
Wisconsin
Have an island sink that I would like to plumb with a PVC union in the cabinet so that I could more easily remove the trap and AAV all together as the AAV is tight between the sink and upper part of the cabinet and will be a pain if/when I need to change it.... I know that the trap is considered a "union" type p-trap, so I assume another union is ok, but thought I better check first....Thanks....
Cacher_Chick
Test, Don't Guess!
If you want to spend the money on a union. It would be quicker and easier and cheaper to just split the vent riser with a banded coupler.
The banded coupling is used quite a bit for plumbing. I woudn't know where to get a union for that.
And yes, they can fail. Being able to replace it is important.
cab1960
Wisconsin
Already have the union. They seem readily available.....I would like to use it in a horizontal position right above the shelf inside the cabinet. Sure makes removing the trap and AAV easy. Unless they aren't allowed, I would like to use it....
