I noticed the rubber washer appears to be different than insinkerator. The insinkerator washers have a groove in the inside that slides around the ridge of the discharge pipe. The waste king washer just sits behind the ridge on the pipe. I'm assuming that the waste king washer just expands outwards to make a seal.
I want to straight pipe the garbage disposer instead of using the 90 elbow that comes with it. I can only find insinkerator straight pipe fittings. It looks like I can just put the waste king washer on the straight pipe instead of using the insinkerator rubber washer. Do you see a problem with this?
