Dirt Sailor
First post! I just purchased a house with this water softener, but it was in bypass "because of low pressure/flow rates". I've never owned a water softener, but definitely want to get it back up and running, and would like to do it myself. It looks like it could be a Fleck 2510, but the dials are not in the same location in the pictures i've seen. I need to know for replacement parts, and how to adjust it for a larger tank (details below).
I took it of bypass and forced a regeneration cycle and the water ran brown/cloudy for a while (I assume because it was in bypass for some time) but then appeared to be providing soft clean water. After a couple of hours, water flow began to drop to the point when running the bath, nothing else in the house would work.
After some googling and research, I determined that the resin was probably bad since we are on chlorinated city water and the resin probably hasn't been touched in 10 years. I also think that the 8"x44"" tank is small for our family size (4) and water hardness (19 grains). I used this site (http://www.apswater.com/Water_softener_Calculator.asp) and determined that I needed a larger tank for our family and to get the flow rates neeed. I just purchased a 12"x52" tank and 2.0 Cu Ft of new resin, new distributor tube and basket (still trying to find a top one that fits; non twist-lock type).
My question is, what do I do to adjust the valve for my new tank size? Hopefully I didn't get something oversized for the valve itself. I sure am glad I found this forum and wish I would have checked here before buying anything! Here are some more pictures.
