Americast Mortar Bed
cpowers
Indiana
Having looked all over the internet and this forum I have found alot of conflicting information, or info that does not apply to my situation. I will post what I plan on doing, if anyone would be kind enough to confirm for deny my methodology.
The tub states that it does not require a mortar base, but I want this job done thoroughly.
In order from top to bottom
Americast Tub
4 mil plastic sheeting
Sand mix (5 dollops appx 2-4 cups each) around the base
Exterior glue plywood
Thank you!
That sounds fine.
Americast doesn't require the mortar under that tub, but it also doesn't hurt to install it that way. It will remove some of the flex.
More and more, I'm seeing mortar as a suggestion for installing pans and tubs.
It never used to be that way. I have recommended it here on my website for years, and many of the ideas I've come up with, have now taken on their own life. Sometimes I see instructions that I've posted here that have been copied verbatim by the manufacturers.
cpowers
Indiana
Thank you, nice to have confirmation, I firmly believe in only doing things once (very lazy). Hopefully you believe that imitation is the sincerest form of flattery, ha!
Chris
A friend called me one day and said his drop in tub was coming off the deck. When I looked at it, one of the water lines had a leak and whatever they used as bedding was expanding and lifting the tub off the floor.
