CountryBumkin
Active Member
I added a whole filter a few months ago. I installed on a piece of plywood mounted to my garage wall.
I noticed that the treaded fitting is leaking at ball-valve connection on the inlet side.
My concern is that I pre-soldered the fittings and screwed everything together prior to mounting - and now to disassemble I will need to heat the elbow fitting next to the plastic filter housing.
Should I be concerned about melting the plastic? If yes, what can I do (wet rag on pipe or ?)?
On my computer this photo is not upside down - but on the "preview" here it shows upside down. I hope it is correct. Sorry if it is not.
Okay so it is upside down - How do I rotate the picture (is there any code I can insert or such)?
