almost no hot water
Discussion in 'Shower & Bathtub Forum & Blog' started by herc435, Feb 26, 2008.
  1. herc435
    herc435 New Member
    Feb 26, 2008
    Canada
    Ok, I have a new hot water tank, lot's of hot water for the tub and bathroom sinks, but in my stand alone shower, there is barely any hot water, even with the single delta handle all the way over to hot. Is there a way I can dismantle this handle, and what should i look for on the inside?
    thanks, marc
  2. jadnashua
    In the process of turning the water on and off at the main to replace the WH, the valve probably saw air in the line, and uneven pressure. This jammed the spool valve to one side and is preventing hot from getting out. From what I hear, sometimes you can disassemble and lube to free it up, sometimes you need to replace the spool valve or if it's in the cartridge, that.
Similar Threads: almost water
Shower & Bathtub Forum & Blog Cold, hot water lines to new bathroom Wednesday at 5:54 PM
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Tuesday at 6:47 AM
Shower & Bathtub Forum & Blog Faucet wall tubes and wall tube escutcheon is not water tight Feb 9, 2017
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
