air gap question...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by zimbu668, Nov 17, 2004.
  1. zimbu668
    zimbu668 New Member
    Nov 17, 2004
    [​IMG]
    If this is a stupid question forgive me. I just got new counter tops installed and I'd prefer not having any extra holes in the them. Is there any reason why the air gap couldn't be entirely below the counter? If it makes any difference I have a 10" deep under-mount sink, so there should be plenty of room to work with.
    Thanks in advance.
    Whirlpool Dishwasher instructions
  2. jimbo
    jimbo Plumber
    An air gap ABSOLUTELY MUST NOT be installed below the counter. If you must, get rid of it completely and connect the DW drain directly to the disposer being sure to loop the drain hose as high as possible to the underside of the countertop, then back down into the disposal . This may not be allowed by code in your are, but in some areas it is an generally without incidents.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    air gap
    Unless required by local code, forget the air gap. The drain hose has to be looped and attached to the underside of the counter, above the level of the dishwasher and in such a way as not to kink.
  5. themax3000
    themax3000 New Member
    Dec 9, 2004
    Some dishwashers now have a "built-in loop"
    Dishwasher manufacturers are finally getting smart and putting a "built-in loop" on the drain line of the dishwasher. Maytag tall tubs are putting in a full height loop. Whirlpool tall tubs, Kitchenaids, Bosch and some GE's are putting in about half-height loops. Perhaps this could solve the"loop" problem altogether! :p
  6. casman
    casman New Member
    Sep 8, 2004
    New York
    I just installed a maytag and did note the loop configuration on the side of the unit, are you saying this eliminates the requirement to loop high up under the sink countertop before tying into the disposer, cause I haven't gone back to secure that loop, which I guess then is a double Loop...... :)
  7. jadnashua
    I know it is trite, but did you read the manufacturer's instructions? They'd tell you if you needed another loop.
  8. themax3000
    Dec 9, 2004
    Loop should be enough
    Let me start by saying I'm not a plumber, so my advice comes directly from being a dishwasher installer. I install 6-8 of these a day.
    The loop is necessary for 2 reasons (albeit related and perhaps the same):
    * To keep dishwasher drain water from draining back into the d/w
    * To prevent siphoning from occuring and drawing waste water into the d/w
    When a d/w has a loop that goes all the way to the top, I in turn do not strap the drain line up under the sink, because, in effect, the task is already accomplished. If the d/w does not, I usually strap the drain line up, or just drill a new hole at the top of the cabinet, running the drain line through the top.
    Hope this helps!
    Rich
  9. casman
    casman New Member
    Sep 8, 2004
    New York
    Good point, I'll have to take a look next time I'm over there, I do remember that there was nothing to read as it was all picture illustrations....which I found irritating....
  10. themax3000
    Dec 9, 2004
    Haven't seen loop in instructions
    I have not yet seen one d/w installation manual mention the need for one (although I must admit, I do not read these with a fine-toothed comb!)
  11. Terry
    Aug 17, 2004
    Here are instructions for installation by Whirlpool.
    [​IMG]
    Check these instructions, it does mention air gaps and high loops.
    Do you ever have your installations inspected by a plunbing inspector?
    What does the homeowner do when he does have the installation inspected?
    I know that every area is different. I knew a plumber from Iowa that didn't know how to test the waste and vents on a home.
    He never used water lines bigger than 3/4".
    But I later found out that the plumbing inspector was his dad's best friend.
  12. casman
    casman New Member
    Sep 8, 2004
    New York
    Hey those instructions would have been helpful, mine was all pictures. My profile had detailed instructions and did mention the loop or air-gap with options for when to use, said something about 18 inches....No I never had it inspected, I'm a lawyer not a plumber, in any event I'd have them plead the 5th if it came up.....
Similar Threads: question
Plumbing Forum, Professional & DIY Advice 1950 Renovation Questions Tuesday at 10:06 PM
Plumbing Forum, Professional & DIY Advice Bathroom plumbing question Tuesday at 11:20 AM
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Tuesday at 6:03 AM
Plumbing Forum, Professional & DIY Advice Moving kitchen sink and dishwasher, vent question Sunday at 6:24 AM
Plumbing Forum, Professional & DIY Advice Dumb, probably repeat laundry standpipe question Feb 16, 2017
