Air Chambers on a Moen Mixing Valve
Discussion in 'Shower & Bathtub Forum & Blog' started by silverfox, Aug 7, 2006.
  1. silverfox
    silverfox Like to build Frank Lloyd Wright Houses
    Aug 7, 2006
    Designer/Builder
    Wisconsin
    Hi Folks...My first post. I am installing a Moen Posi-Temp L82680 shower control in a remodel and I need to know how and where to install the air chambers. I've never done it with a single mixing valve before. I think I would just install a vertical "T" fitting at the ends of the short pipes coming from the valve and install the supply lines to the bottom of the hot & cold T's and then rise the air chambers 12 inches from the top of the T's. Is this correct? The sooner I get an answer to this the better and I appreciate any help I can get. THANKS!!
    Mike
  2. Terry
    Aug 17, 2004
    The posi-temp doesn't need air chambers or hammer arrestors.
    It's not a quick closing valve.
    Quick closing valves are
    dishwasher
    icemaker
    clothes washer
    Most codes call for hammer arrestors, not air chambers.
    If you use an air chamber on the valve, you can use tees.
    I've used 3/4x1/2x1/2 tees, with a 18" 3/4" pipe and 3/4" cap.
    It's not code anymore, but will work until it waterlogs, which is pretty quick.
  4. silverfox
    Aug 7, 2006
    Designer/Builder
    Wisconsin
    WOW....an answer from the guru. THANKS, Terry!
    UM....well...I have used air chambers (don't know what a hammer arrestor is??) throughout the house because they were used prior to my remodel. I hope that's ok because most of the house is drywalled. I guess, since you say that I don't need the chambers in my shower set up I will just leave them off and do without them. Hey...you're the boss. Wish I knew what hammer arrestors were. And I hope I haven't screwed up this remodel by trying to do everything right. BOY ... do I ever hope that!
    Thanks again, Terry....thanks a LOT.
    Mike
  5. jadnashua
    A hammer arrestor is a little chamber with either an air bladder or a piston in it...there is no direct air to water interface. With what you have, very shortly after you turn on the water, the air is disolved into the water, and they become useless.
  6. silverfox
    Aug 7, 2006
    Designer/Builder
    Wisconsin
    Thanks, Jim....I ran into a plumber friend and he told me the same thing Terry told me about the items that need the arrestors. I put them in everywhere so far because they were there in the old installation. My friend told me that it wouldn't hurt anything...for which I am happy. Just more work for nothing.
    Thanks again for the help......hey Jim....I'll see you again over at the John Bridge site.
    Mike
  7. jadnashua
    I spend more time than I should on these two forums...
  8. Mikey
    Nov 8, 2005
    Consumer
    Northern Washington
    What? No time for Mike Holt?
Similar Threads: Chambers Moen
Shower & Bathtub Forum & Blog Garden Tub Moen Trim Replacement Jan 29, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Moen s3600 valve cartridge removal Dec 10, 2016
Shower & Bathtub Forum & Blog Moen tub faucet cross member broke Dec 3, 2016
Shower & Bathtub Forum & Blog Help with removing Moen shower handle hub Nov 27, 2016
