Advice on the right pump for my project
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by flurver, Apr 10, 2013.
  1. flurver
    flurver New Member
    Apr 10, 2013
    Los Angeles
    Hello.
    I am working on a photography project and looking for some advice.
    I have a shower head like device that is hooked up out doors with my garden hose plugged into it which will be running for a couple hours at a time while I shoot photos.
    This works fine but I would prefer not to waste water so my plan is to use a kiddie pool with a pump to recycle the water, when I am at home.
    This same setup will also be used in the great outdoors (with a battery power pack) using a stream, lake, or ocean as the water source so for this reason I would like the pump to have a hose inlet and outlet as opposed to a submersible style pump.
    I would appreciate any suggestions on a pump that can deliver roughly the same flow of water as a typical garden hose, is small/portable, that works well even though it may be a fair distance from the water source, and can operate for hours at a time with no problems.
    I've experimented a bit with a harbor freight pump (http://www.harborfreight.com/12-volt-marine-utility-water-pump-94639.html) but it's rate a flow was a weaker than I would like (not as good as the garden hose) and some reviews state that it is not intended for extended use.
    If I'm missing anything or if more information or a better description would help let me know.
    Thank you for any help
    Charlie
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    It is a lot easier to push water than to draw water up. Something like this will pump five times more flow.
    http://www.walmart.com/ip/BJM-Pumps-1-12-Volt-Battery-Submersible-Pump/11375517?ci_src=14110944&ci_sku=11375517&sourceid=1500000000000003260430&adid=22222222227000000000&wl0={matchtype}&wl1={network}&wl2={ifmobile:m}&wl3=21486607510&wl4={aceid}&wl5=pla&veh=sem#ProductDetail
    Or you can use two or three of the pumps you have in parallel.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    If the volume is limited by head, I doubt two or three in parallel will make much difference. Now, pumps in series might...
  5. valveman
    Mar 15, 2006
    Lubbock, Texas
    Of course, but if the volume is not limited by head, another pump in parallel would double the volume. And those little pumps will build like 65' of head. They don't last very long though. I use them to empty out water containers at trade shows. Mine came with some extra rubber "blades", wouldn't call them impellers. They work pretty good for short periods of time. I used up all my extras over a few years.
    That submersible type pump lifts a lot more water, but it won't do as much head. Usually need larger pipe to limit the head to get more volume.
  6. flurver
    flurver New Member
    Apr 10, 2013
    Los Angeles
    Hey guys, thanks for your replies.
    Only reason I am hesitant to use a submersible pump is because access to water sources might be easier obtained with a hose than a submersible pump.
    For example if I was pulling water from the ocean I would rather throw a hose in vs throwing or wading out and putting a submersible pump in.
    That said if a submersible is superior than I would probably make the compromise.
    Along the same lines, would I need a specialized pump for salt water?
    Thanks
  7. valveman
    Mar 15, 2006
    Lubbock, Texas
    I think it is easier to throw a submersible in where I want it than to get the end of a hose weighted enough to stay down, but not too far down.
    Salt water needs all Stainless Steel or all plastic. But even iron will last for a little while, if this is a not a permanent install.
Similar Threads: Advice right
Pumps and Tanks Well Forum & Blog. Water is life. Well pump replacement and bad advice Tuesday at 4:05 PM
Pumps and Tanks Well Forum & Blog. Water is life. New Well, Need Advice on Systems Jan 27, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Newbie needs advice Cycle Stop Valve Dec 29, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Working on well. Need one more bit of advice Dec 9, 2016
Pumps and Tanks Well Forum & Blog. Water is life. CSV and pressure tank advice? Sep 28, 2016
