Ioiwin, what size and shape is your brine tank?
You need to ensure there is enough salt remaining to allow the programmed capacity to be restored. Your programmed salt setting is 16lbs to restore 48K capacity. As long as more than 16 lbs salt is within the brine tank, the system will have enough salt. One method to judge and ensure there is enough salt remaining is to observe salt above the water level.
While you mention the height of the water, that liquid height will change depending on the amount of salt in the tank. Even as your 11 minute BF @ 0.5 gpm will add 5.5 gallons to the brine tank, if there is little salt, the liquid height will be significantly lower than when there is plenty of salt.
The liquid height appears to be increasing as every 1 gallon entering the brine tank, will dissolve 3 lbs of salt. As you have added water to the tank multiple times, the salt height is decreasing.
34 inches high, and 14 inches square at the top, tapering down toward the floor?Believe it’s a 14” x 34” shaped like a rectangle
Keep the salt tank full of salt. Check the level periodically. The system will refill with a predetermined number of gallons of water so salt levels are not critical.
Ioiwin, if I model your tank as a 13 inch square down where the salt is, your 5.5 gallons of water added would be expected to raise the water level by about 7.5 inches. That would be on top of whatever residual brine/water is left after the air check valve cuts off. That lower level could be considerable, especially if you have a salt grid. If I model it as a 12.5 inch square, then I get a predicted 8.1 inches of rise over the low water mark.
Your corners are rounded a bit, so that is part of why I used the smaller squares as models. The other part is the taper. These are not precise numbers by any means.
You keep some salt above the water. Whether you keep the salt level lower, or fill it to the top is up to you. I like lower initially to see things work. I did that. Now I put a lot more salt in than I did during my check-out phase.
Edit to add: Assuming all brine had been drawn before you halted BF with 5 minutes remaining, then there will only be 3 gallons usable in the brine tank, not 5.5 gallons. As 5.5 gallons is needed to dissolve 16 lbs to restore 48K, then 2.5 gallons will need to be added to the brine tank. As you have now sanitized the system and if the water to the fixtures is clear, suggest allowing the system to regenerate automatically when the programmed capacity has been consumed.
If the water level is above all of the salt, the water can stratify. Brine is denser than water.Thanks for the thoroughness. So if when after every few months or so I see the salt getting below the water line, then add some more salt? The installer said to add a couple of bags when the salt is a few inches from the bottom. Sorry if I keep asking, I am just unclear of when to actually add salt.
Expect to consume a 44 pound bag of salt about every 4 regenerations.
You are right. I will edit my error.At my age I hate reading something like this and then questioning my sanity. How does he get 4 regenerations out of a 44 lb. bag when he is using 16 lbs. each time??
This was already addressed in post #83.Do you guys recommend I add 2.5 gallons water
Do you think there is no chance that while this is new he will have to maybe raise the brine float because that is limiting the fill, or have to do something else that might be hindered by the brine tank packed full? No harm in letting this thing work through a couple of regular regens before packing it full IMO.With regard to the salt level, fill the brine tank to the top.
OK. He has a small brine tank with a 2 cuft softener. So brine level will be higher than most.The float is easily accessed through the brine well cap even if the tank is full. The float should not need to be adjusted so long as the float is adequately high. The float is nothing more than a safety backup.
