Depends on who you hire. If you hire a plumber, he/she may have no prior water treatment experience and may not have any idea how to program the unit. An alternate option would be to hire an installer from a local water treatment company as that person should understand how the system is to operate but may not appreciate that you didn't buy it from his company. You could also choose to install and program it yourself.If I have someone install the softener will they should they be knowledgeable to achieve this if I tell them?
Not sure why you would want to manually regenerate as the system is automatic and will regenerate when required. One possible exception would be when multiple house guests are expected to arrive when the softener is almost due to regenerate. The additional water use may exceed the remaining capacity and reserve before regeneration will take place at 2am so you may choose to initiate an early manual regeneration cycle to ensure adequate soft water will be available when needed.If when regenerating only a few days early before my capacity is up,
Depends on the seller of the equipment. Some ship their systems with gravel, resin the bottom basket and riser already in place with the control valve on the tank wheras others, ship the components separately with an expectation you the customer will be assembling it.Does the seller put the gravel in for me before delivery/purchase?
In paying attention to the salt efficiency specified above, you will find the 1.5 cuft and 2 cuft softeners can be programmed to provide the same exact salt efficiency. The 2 cuft softener will use more salt per regeneration cycle due to the larger capacity contained, but will also require less frequent regeneration cycles due to the increased capacity.
A 1.5 cuft softener will typically utilize a 10" diameter tank which will require 2.4 gpm BackWash and Rapid Rinse flow rates whereas the 2 cuft will use a 12" tank which will require ~3.5 gpm.
There will also likely be a slight variance in Brine Draw and Slow Rinse flow rates depending on the injector installed in each. While the 2 cuft will use higher gpm, the reduction in regeneration frequency may offset any additional water use.
You seem to be obsessed with 30,000 grain capacity for some reason. If you're stuck on that, use the 1.5 cuft with a 6 lb/cuft salt dose. If planning to purchase a 2 cuft, the appropriate programmed capacity with a 6 lb/cuft salt dose would be 40,000 grains.
In http://www.cwwltd.com/content/pdf/Purolite-C100-Operating-Data.pdf and http://www.filterwater.com/t-water_softener_cation_resin.aspx figure 3 illustrates salt dose vs capacity. So that would make it seem that the leaner the better. But also see figure 5 -- hardness leakage. That is the main downside of too little salt for regen.With a 2 cf softener, am I able to try to soften less than 40k grains? For example, am I able to try to soften 30000k instead? Which salt dose would I choose in this case and are there any drawbacks? Thanks
No. Yes. ummm.... not sure how to answer that third one... you will have good salt and water efficiency, but you will have hardness leakage.Does this sound ok to you guys (gals)? Is the time between regenerations too long? Am I using the softener correctly to maximize salt and water efficiency?
I predict that maybe in the third week you will see significant hardness leakage. No catastrophe. When that happens, change C to 41 for 6.25 pounds of salt per cuft.
What controller do you have?
I did not say it is not efficient. Ditttohead has recommended a maximum 30 days for day override. Good enough for me. I don't expect the DO to come in to play for you unless you are on vacation.I have Fleck 5600sxt. Can you please explain why it’s not efficient and why regeneration time being that long is bad?
That would be what grains of softening I expect you would get using 12.5 pounds of salt in 2 cuft of resin. 64000 grains (C=64) is what you would expect with about 18 pounds of salt per cubic ft of resin for each regeneration. Not salt efficient.Also, can you clarify what a value of 41 for C means? I’m assuming my C now is 64?
I don't know how you would get 6.25 pounds/cuft anyway. With a BLFC of 0.5, BF=8 gives 6, and BF=9 gives 6.75 lb/cuft. One minute is the granularity on BF.
So anyway, here is a stab at some reasonable settings for you:
System info (not programmed)
salt lb/cuft = 6 ; A choice ( efficiency vs capacity)
BLFC = 0.5 ; Brine Refill rate GPM
cubic ft resin = 2 ; ft3 resin = (nominal grains)/32,000
Raw hardness = 13 ; including any compensation
People = 4 ; gallons affects reserve calc
Estimated gal/day = 240 ; 60 gal per person typical calc
Estimated days/regen = 12.8 ; Computed days ignoring reserve
Fleck 5600SXT Settings:
DF = Gal ; Units
VT = dF1b ; Downflw/Upflw, Single Backwash
CT = Fd ; Meter Delayed regen trigger
NT = 1 ; Number of tanks
C = 40.0 ; capacity in 1000 grains
H = 13 ; Hardness-- compensate if needed
RS = rc ; rc says use gallons vs percent
RC = 240 ; Reserve capacity gallons
DO = 30 ; Day Override (28 to 30 if no iron)
RT = 2:00 ; Regen time (default 2 AM)
BW = 5 ; Backwash (minutes)
Bd = 60 ; Brine draw minutes
RR = 5 ; Rapid Rinse minutes
BF = 8 ; Brine fill minutes
FM = usually t0.7 ; flow meter, make note of what is there
To be more precise, you will have a countdown on the display (alternating with time). When that hits zero, the softener thinks you have 240 gallons (RC value) left. That could be at 7 am. That's OK. You are into the reserve. The "service indicator" (faucet icon) will flash saying that a regen is planned for 2am.I will program for 40,000 grains so that will use 6 lb/cf salt and will regenerate once we use up the 40000 grains which at 13 gpg and roughly 1700 grains used per day would regenerate every 23 days or so?
He has been told it is a "64000 grain" softener. He told people that. So he does not want to be inconsistent. That's OK. It did not really hurt you, because you were thinking of cubic ft, as you should. The 64000 should be looked at a convention rather than a useful number.Can anyone explain the thought process of my installer? He set Capacity to 64... how many lbs of salt per cf does that equal? Why would he do this?
DF = Gal ; Units
To answer this question, your softener containing 2 cuft of resin has a total theoretcical capacity of 64,000 grains when regenerated with 36 lbs of salt every cycle. Using and restoring 100% of capacity results in extremely inefficient salt consumption (64,000 / 36 = 1,777 grains per lb) and other issues.So as he programmed the C to be 64, what salt dose is this?
First 2, no big deal. Not critical. Shorter saves a little bit of water.BW = 10
RR = 10
BF= 16
Back Wash will flushout any debris which happens to enter the softener in the incoming water. BW will also expand and reclasify the resin bed so to eliminate any channelling which may have occurred since the last regeneration cycle, while also allowing the brine to easily flow between the resin beads to increase resin contact during regeneration. A 10 minute BW is fairly standard for most softener's and will help ensure the resin bed is appropriately expanded and reclassified.Would BW = 5, RR = 5, BF = 8 work better for setting at 40000 grain capacity? What exactly do these settings do?
BF, that is a big deal. Do you have a label similar to this on your softener?
If you don't have a label, I am suggest that you look at the BLFC button. We can discuss how.
For C and BF, see table below. I underlined two choices near 8 lb/cuft. The ones near the underlined values would be good too. If you can only do whole numbers for C, then you can round. So BF=10 and C=46 would be good. Let us know if the controller accepts C in tenths.f I go with 40000 capacity, what BW, RR, BF do you guys recommend and what if I went with ditto’s 48000 capacity?
