AC Drain Pipe
Mohammad Ali
Karachi
Hi guys. Actually I want to drain the AC condensate outside my window. Whenever I try to do this by giving a slope through channel ducts, the water bursts out from the pipe. Furthermore, the door in between also causes hindrance. As a result, I have to drain down the condensate straight from the pipe down to the water gallon which is not an effective solution. So please can you guys suggest how can I give a proper slope to drain the condensate right outside the window?
The horizontal distance is 9.5 ft.
Please go through attached pictures for better visualisation.
Fitter30
Peace valley missouri
What is the pipe coming out of? Air handler coil before blower has to be trapped before blower no trap if coil is after blower. Have to over come the negative pressure ah before blower 1" more than enought.
