3 Grains Hardness after Softener in New House
rural_engineer
New York
I've been consistently getting about 3 grains of hardness on a brand new softener with brand new plumbing, even after regenerating several times and using the hot and cold water pretty heavily. I've been checking it with a Hach 5B. What might be causing this, and how can I troubleshoot it?
I've had my well water tested by a mail-order lab and the local health department.
Tapscore: 0.56ppm Iron and 25.46gpg hardness
Heath Department: .08mg/L Iron and 376mg/L total hardness
My own Hach 5B: Between 25 and 26 grains hardness
(I also had a pushy water softener salesman do a test, and he found 18gpg and no iron)
I've got a 2 cu.ft. softener with a Fleck 5810XTR2.
ditttohead
Water systems designer, R&D
Ontario California
Put the system into brine and slow rinse cycle and taste the water going to the drain after 1 minute. It should not be salty. Salty water should get to the drain after 5-15 minutes. Let us know what you find.
rural_engineer
New York
Here are the current settings:
VALVE:
Valve: 5810
Regen type: Softener Meter Delayed
Media Volume: 2 cu ft
Salt Dosage: 8lbs/ft^2
blfc size: 0.125gpm
Capacity: 45236 grains
Hardness: 27gpG
Sensor sensitivity: NA
Day override/time-driven: off
Regen time: 2am
reserve: Weekly reserve
REGENERATION:
Regen flow: downflow 2x backwash
Step 1: Backwash
Time 1: 10 m
Step 2: Draw
Time 2: 120 m
Step 3: backwash
Time 3: 5 m
Step 4: rapid rinse
Time 4: 10 m
Step 5: Tank refill
Time 5: 43 m
RELAY OUTPUT:
Auxiliary 1: off
Auxiliary 2: off
METER:
Meter type: 1.25" turbine
generic: NA
emerg. regen: off
CONTINUOUS FLOW DETECT:
continuous flow detect: off
flow rate: na
duration: na
REMOTE REGENERATION:
Remote signal duration: off
WATER SAVER REGEN:
Water saver regen: off
CHLORINE GEN / LOW SALT:
cl generation / low salt: off
regen interval na
For the record, it has a 00 injector and a 3.5GPM DLFC. It's a 12" tank.
I'll do the brine taste test when I next have time, maybe tomorrow night.
Nice job posting the settings.
If you have a TDS meter, you can use that instead of tasting. Expect the TDS to go up a lot, over 1000, when the salt hits. Taste works too.
rural_engineer
New York
Brine test was a clear failure. I could taste salt after 30 seconds, and it was really salty after 60 seconds. What's next?
ditttohead
Ontario California
Dang I'm good. :)
Remove the valve and check the riser o-ring/clip. It needs to match the riser pipe size. The 5810 is available with 3 different riser tube sizes, all use the same valve, just a different adapter kit.
ditttohead
Ontario California
Post pictures, the problem is very easy to correct. Here is a video of the 7000 riser, almost identical to the 5810.
rural_engineer
New York
Any suggestions for where I can source that quickly? I'm sure my water softener supplier will eventually send me one, but I really would like to get one by Friday.
rural_engineer
New York
With the new riser adapter the cold water is now completely soft. The Hach 5B shows blue without any drops of the liquid reagent.
ditttohead
Ontario California
Congrats on a successful fix! The riser assembly on the 5810 is very unique in that it accommodates 3 different size riser tubes. This is good and bad as you found out.
