3" Drain clean out
Discussion in 'Toilet Forum discussions' started by KShirriff, Nov 9, 2012.
  1. KShirriff
    KShirriff New Member
    Nov 8, 2012
    Tuscaloosa, Al.
    What do you typically use when placing a clean out in main line? Is it a wye or a combination wye tee or does it matter? Also, can a san tee be used on the vertical stack for a clean out?
  2. Chad Schloss
    Chad Schloss Member
    Jun 18, 2010
    USA
    is the main line vertical or horizontal? if vertical , use a cleanout tee / test tee . if horizontal, use a combo or y and 1/8 bend. some i have seen even have a wye 1/8 bend in the opposite direction to cleanout both sides.
    i'm not a plumber but an avid diy'er. a plumber may come along to assist.
  4. Terry
    Aug 17, 2004
    A cleanout can be installed on a santee on the vertical
    A test tee is fine too.
    Basically you just need access to drop the cable. Something with sweep is nice, but not necessarily a code item.
    What is code, is the requirement to have a cleanout every 135 degrees of horizontal change of direction. That's a 90 plus a 45.
  5. KShirriff
    Nov 8, 2012
    Tuscaloosa, Al.
    Thanks...I really appreciate the advice.
Similar Threads: Drain clean
Toilet Forum discussions Is there anything with large drain, great bowl clean, OK with softscrub, and not white? Jul 14, 2016
Toilet Forum discussions Best Toto for bowl cleaning and bolt to drain pipe Nov 7, 2010
Toilet Forum discussions Toto CST864 Water Won't Drain from Toilet Feb 25, 2017
Toilet Forum discussions Replace rear drain with a ground drain toilet Dec 12, 2016
Toilet Forum discussions Another slow draining/bubbling thread Nov 13, 2016
