200 Amp breaker
Discussion in 'Electrical Forum discussion & Blog' started by Ian Gills, May 21, 2010.
  1. Ian Gills
    Jul 24, 2007
    USA
    The 200 amp main breaker in my new Square D panel is tough to switch on and off, and certainly more stiff than my old 100 amp one.
    Is this normal?
  2. jadnashua
    The contacts are twice as large, so yes, I think it is normal for it to be stiffer. It also uses a bigger spring to ensure it can break the connection. To overcome the effects when 200A is flowing, and the resulting heat, it applies more pressure to the contacts so they can achieve minimal voltage drop across.
    On super large breakers, they have a rachet handle to pump it back closed.
  4. Ian Gills
    Jul 24, 2007
    USA
    Thank you, and very informative.
Similar Threads: breaker
Electrical Forum discussion & Blog Installing an AFCI breaker Jan 5, 2017
Electrical Forum discussion & Blog 20 amp breaker trips Nov 8, 2016
Electrical Forum discussion & Blog Running a 36amp load on a 40amp breaker Sep 15, 2016
Electrical Forum discussion & Blog 240v breaker serving two heaters Sep 13, 2016
Electrical Forum discussion & Blog Connecting surge suppressor to spa GFI breaker. Aug 17, 2016
