2 main irrigation shutoff valves?
Discussion in 'Irrigation / Sprinkler Forum' started by Handiman, Apr 18, 2009.
  1. Handiman
    Handiman New Member
    Apr 18, 2009
    Nevada
    Hello, I have a 20+ year old house with everything RAINBIRD. I'm having trouble turning on the water after the system was winterized (first time trying this).
    I have 3 zones with 3 antisiphon valves (1 foot underground) and a backflow preventer (above ground). It looks like I have 2 main shutoff valves for the irrigation system (both of these valves are 4 feet deep). I opened 1 valve and the other 4 foot deep valve hole filled up and pours out water. How do I dewinterize this system? What is the idea behind having these 2 main shutoff valves? The main line shutoff valve is at the street (which of course is always on).
    Thanks
  2. Handiman
    Handiman New Member
    Apr 18, 2009
    Nevada
    Well looks like the main irrigation shutoff valves are right before the PVB (pressure vacuum breaker) and then right after it. What is the sequence for turning on the water without the water filling and pouring out of the main irrigation shutoff valve after the PVB backflow preventer? Never thought it was going to be this complicated.
  4. Handiman
    Handiman New Member
    Apr 18, 2009
    Nevada
    LOL, well I figured it out myself. The valve after the PVB (pressure vacuum breaker) was actually a drain valve (hence water filling up tube), so all I had to do was turn it clockwise (shut) and all is working great. GEEZ that took forever to figure out something so simple.
  5. PSLawnService
    PSLawnService New Member
    May 16, 2009
    Lawn Service - Owner
    Minnesota
    The best person to start up your irrigation system is the person who winterized it. Usually......
Similar Threads: main irrigation
Irrigation / Sprinkler Forum Bury drip irrigation main connected to hose bib? Mar 4, 2017
Irrigation / Sprinkler Forum Drip Irrigation system often leaks at barb connections to mainline Jun 22, 2016
Irrigation / Sprinkler Forum Connecting irrigation to water main with pex homerun system Apr 11, 2012
Irrigation / Sprinkler Forum Adding a hose bib to main irrigation line? Jan 6, 2009
Irrigation / Sprinkler Forum Help with sprinkler pump and main line for irrigation Sep 3, 2006
