2" copper dwv in kitchen
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Andrew21, Feb 23, 2014.
  1. Andrew21
    Andrew21 Member
    Jun 21, 2006
    New York
    Hey all,
    I have a 2" dwv in my kitchen and wanted to get this setup for my new sink, and cabinets that are coming in.
    I know the usualy fittings for a kitchen sink drain is 1-1/2". So to get this to connect to the 2" copper dwv, do I:
    1. Get a 2 in. x 1-1/2 in. Copper DWV CxX coupling and put on a trap adapter?
    http://www.homedepot.com/p/Mueller-...n-Copper-DWV-C-x-C-Coupling-W-67073/100132768
    or
    2. get a 2" reducer to 1-1/2" and put a trap adapter at the end of this?
    THank you!
  2. Terry
    Aug 17, 2004
    Normally a kitchen trap arm is 1.5"
    If you have a 2.0" trap arm, it will need to be reduced to 1.5" and a trap adapter.
    [​IMG]
    This is 1.5" copper DWV, from and old 60's home. They also make couplings that transition between copper and plastic.
  4. hj
    If I read your question correctly, both of those fittings are the same, but you can do it almost anyway you want to as long as you wind up with a 1 1/2" connection to the sink.
  5. Andrew21
    Andrew21 Member
    Jun 21, 2006
    New York
    Thank you Terry and HJ! I'll post pics when I can.
  6. Andrew21
    Andrew21 Member
    Jun 21, 2006
    New York
    Hey guys,
    Ok, so I was successful in getting a copper 2"x1-1/2 reducer. Now when I put the 1-1/2 trap adapter to the reducer size, its the same size and it won't fit. Did I buy the wrong piece?
  7. hj
    No, you need a short length of 1 1/2" copper to go between the two pieces.
  8. Andrew21
    Andrew21 Member
    Jun 21, 2006
    New York
    Thank you HJ.
Similar Threads: copper kitchen
Plumbing Forum, Professional & DIY Advice Copper pipe support under kitchen sink? Sep 5, 2010
Plumbing Forum, Professional & DIY Advice Copper Kitchen Sink- Need Advice ASAP! Apr 30, 2010
Plumbing Forum, Professional & DIY Advice Kitchen faucet copper pipes Jan 20, 2010
Plumbing Forum, Professional & DIY Advice Kitchen faucet - bending copper supply tubes Jul 29, 2008
Plumbing Forum, Professional & DIY Advice Do I use copper or cast iron for soil pipe running down kitchen wall? Jul 30, 2006
