1stTimeHomeOwner
Hello! I'm happy to have found this forum. It has been quite the experience with my first bathroom remodel (learned about tile, drywall, electrical, plumbing/sewer line, etc...). So far, we have been really happy with the results.
I'm hoping someone can point in the right direction with the plumbing connections on my bathroom remodel. Note: The house is an older 1953 house... Please reference the pics below of the current setup.
Bathroom Sink Water Supplies and Drain (I removed the drywall to attach additional stud support for the wall mount vanity)
Close-up of Sink Water Supply connections
Toilet Water Supply
It's worth pointing out that the bathroom was rarely used due to low pressure of the faucet and toilet valve. We found the cause for the low pressure was the fixtures (bad sink faucet and bad valve in the old toilet tank - not a line issue). We are replacing everything with new parts. The water did come out brown which I believe might be tied to the galvanized nipples/valves, etc.. so any advice on replacement options is appreciated.
What is recommended to clean this all up? I'm not sure if this is DIY, or if I should hire a plumber to assist with this part. Plumbing is a bit intimidating to me, but I have enjoyed learned and I'm willing to attempt it unless its too much for a first timer. Thank you for any help!
Toilet Water Supply
