13 1/2" rough, Toto Carlyle
Discussion in 'Toilet Forum discussions' started by lexilooooo, Sep 29, 2004.
  1. lexilooooo
    lexilooooo New Member
    Sep 28, 2004
    [​IMG]
    I just started a small DIY bath remodel and I was surprised to find that my toilet has a 13 1/2" rough. The two other toilets in the house are exactly the same, but the rough is at 12". It looks like a 12" toilet was install because I have a 2 inch gap between the toilet and the wall, that was hidden by the counter bango.
    Now I need to replace the toilet, the bango is no longer going to be on the wall so the 2" gap will be seen. How do I fix this?
    -Will the Toto Carlyle with concealed trapway that is field adjustable work? Is the Carlyle as good as the UltraMax.
    -Do I need to get a plumber out her and move the rough (bathroom is on second floor).
    -Do I learn to live with the 2" gap?
    -Expo mentioned they could order something to adjust, but that just scares me. I'm already concerned about going to low flow toilets.
    What are my options?
    Any help would be appreciated.
    Thanks
    Kris :eek: :confused:
    Kris,
    With the 14" Unifit, you would have 1/4" behind the toilet.
    With the 12" that coms with the Carlyle, you would have 2 1/4" of space.
    On the Carlyle, the water supply needs to be 7" to the left of center.
    If it is closer it will hit the back.
    Terry Love
  2. e-plumber
    e-plumber DIY Senior Member
    Sep 1, 2004
    New York
    13 1/2" Rough
    One option would be to install a 14" toilet, it should fit.
    You would need to get the cut sheet for the exact toilet that you're interested in and confirm that it will fit.
    Toto's website and most all fixture manufacturers have this info available.
  4. jimbo
    jimbo Plumber
    Toto has something called a "unifit" adapter. I am not familiar with how it works, but Terry Love hopefully will weigh in or if ot you could e-mail him. He is the Toto Guru!
  5. jadnashua
    You really need to get the manufacturer's spec sheet for the specific toilet you want. The Toto (not all of them use this) unifit adapter comes in 10, 12, and 14" versions. Basically, this adapter has the trap (at least it appears to), the toilet mates with the adapter. You mount the adapter over the toilet flange, bolt it to the floor (it takes not only the flange's bolts, but I think 4 more in the floor), then set the toilet on the neck that fits up from the adapter. The toilet has a rubber gasket that seals it to the unifit adapter. Then the toilet is bolted to the adapter. They use different length traps in the adapters to move the body of the toilet away from the wall the desired offset.
  6. jadnashua
    I just looked at the Toto spec sheet for the toilet - it appears that there is 3/4" clearance between the back of the toilet and the wall on a standard install. If you went with the 14" Unifit adapter, you'd have 1/4". This would leave no room for the baseboard, and if the wall wasn't plumb, you may have other problems. BUT, it looks like it would work. Double-check your model and how plumb your walls are - you may be able to live with 1/4" verses the design 3/4". This may be better than the 1-3/4" you'd have if you went with the 12" rough unifit.
Similar Threads: rough Toto
Toilet Forum discussions TOTO Ultramax II rough in distance Jan 31, 2017
Toilet Forum discussions Replacing Toto Ultimate round bowl, 14" rough in - no knee room Jan 21, 2017
Toilet Forum discussions Toto Entrada and rough size Jan 19, 2017
Toilet Forum discussions Rough in question for TOTO Aquia Oct 26, 2016
Toilet Forum discussions Standard Height Toto with 10" rough in? Oct 16, 2016
