Rough in 17"
ouikikazz
Ny
So, due to a joist being the way my toilet rough in is 17...had they place it on the other side of the joist (which I think would've been smarter) rough in would've been closer to 13" but that's neither here or there now, it's a bit late to move the rough in without massive drywall and tile work.
With a 2" offset it'll bring that rough in to 15", can I think use a 14" toto unifit toilet to minimize the gap? I would prefer to find a way to make my original decision of a toto drake work but I can potentially swallow the price difference for a aquia iv
You can improve things using a Toto Vespin iI with a 14 inch Unifit.
I ended up using a 12 inch Unifit to about a 13.25 rough.
My vespin uni-fit story / saga:
http://www.terrylove.com/forums/ind...baseboard-and-shoe-molding.58080/#post-428138 my unifit mod post
http://www.terrylove.com/forums/ind...nifit-or-stick-with-the-12.59681/#post-442544 picture with ruler.
http://www.terrylove.com/forums/ind...rance-with-14-unifit-and-offset-flange.66596/ has marked-up unifit photo.
HOWEVER, my flange was a 4 inch, so there was a bigger hole to hit.
too bad no one knew any better during the rough stage . hope it works out , if its a conventional joist it might be possible to do a little notching
If this bathroom is over a basement or crawlspace, I don't see massive drywall plus tile work. Maybe one or the other. The toilet would cover the changes in the basement floor.
But if this is over a finished basement or is on the second floor, yes, I could see significant drywall work.
A "space saver" over the toilet tank would help camouflage the remaining extra gap.
