100 year old drain line professional augering?The kind with blades to remove build-up
Discussion in 'Drain Cleaning' started by CanOfWorms, Aug 5, 2013.
  1. CanOfWorms
    CanOfWorms Member
    Feb 17, 2013
    Appraiser, Property manager, Realtor, DAD.
    New Jersey
    Line currently blocked and when something up top gets flushed it backs out of basement toilet.
    I will let it sit for several hours till the water seeps out.
    I'm going to snake until I get some flow then put the hard-core sulfuric acid stuff that sizzles when you put it down the line.
    This will get me out of the woods.
    I want to call in a pro to do angio-plasti on the lines. I saw a skecth at the supply house with different augering bits.
    What is the safest cutting augering bit/ tecnique.
    I don't want to do the pressure blast since My pipes are old and run under the concrete floor the length of the basement, so I don't want to risk someone breaking a connection.
    If I had to guess the lines sit in sandy dirt with a two inch layer of hand poured concrete.
  2. CanOfWorms
    CanOfWorms Member
    Feb 17, 2013
    New Jersey
    Any thoughts on the auger to permanently remove build up in the pipe?
  4. joemcl
    joemcl In the Trades
    Mar 2, 2013
    licensed journeyman plumber
    Pennsylvania
    If you are going for best cleaning , I would have the lines water jetted.
  5. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Be absolutely certain to tell the plumber what you have done there so s/he does not get any ugly surprises.
  6. Terry
    Aug 17, 2004
    I don't like the idea of putting acid in the pipes. Rotting out the pipes with acid when you can't get at them doesn't make a lot of sense.
    I would snake first, then use something safe on the pipes like Bio-Clean to remove left over grease. Instead of burning a small groove down the bottom of the mess, it eats to goo around the entire diameter of the pipe.
Similar Threads: drain line
Drain Cleaning Cleaning blocked exterior drain line... Jul 30, 2014
Drain Cleaning Clog in the main drain line Apr 11, 2014
Drain Cleaning PVC storm drain line has serious roots -- clear it? or start digging? Nov 9, 2011
Drain Cleaning New sink, with a new drain line, smells musty Sep 8, 2010
Drain Cleaning Drain Line (Snake) Advice Dec 3, 2009
