1 inch well pipe plastic
Kookieman 69
Va
I need to connect 2 pieces black plastic pipe 1 inch IPS is that butts together within 1/2 inch there is not enough room to move either way after installing
Kookieman 69
Va
What about before installing?
Its a 12 inch section of pipe I am adding a shut off valve with Barbed fittings each end of pipes cannot be moved I am cutting out section of pipe installing the valve if I measure tight I will have the 2 pipes butting together will a Fernco coupling be strong enough also ideally would be a compression fitting I could slide on 1 side of pipe then slide on center of gap and tighten
Kookieman 69
Va
This is what it will. Look like when finished if I could get compression fitting to slide on 1 end then slide on other end after install and tighten would have to be able to slide thru fitting. Can't load picture but would, be 1/2 inch gap
Kookieman 69
Va
No Fernco.
I was thinking of a valve between two unions, but you would need precision in measuring. https://www.supplyhouse.com/True-Union-Ball-Valves-22191000 for example if a good PVC valve is acceptable to your plan. Insert barbs would be screwed into each end.
Better might be a pair of elbows to your valve rather than going for something right in line.
Do you understand that you don't want a valve that can be shut off between your pump and your pressure switch?
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
Poly pipe needs barb fittings. If there is no room to spread the ends to insert a barb nipple, then go with a union ball valve as reach4 suggests. You can use thread-to-barb fittings into the ball valve and union.
With black poly pipe using insert barbed fittings, the union sounds like a good idea.
Or you can use for 90's and the part with the valve can drop in from the side or at a angle of your choosing.
It wouldn't be a straight line, but the offset means you don't have to pull the ends back.
