Zone valve problem
Discussion in 'HVAC Heating & Cooling' started by Ironworker1143, Jan 4, 2009.
  1. Ironworker1143
    Ironworker1143 New Member
    Jan 4, 2009
    I have a wood boiler and oil boiler hooked togeather to heat my home. Problem is Downstairs Thermostat will not open zone valve and cirrculating pump will not start. All the other 3 in my home work great.
    If I hold open zone valve manuall for the downstairs zone . The Pump with work and the zone will open. as so for the other valves I took thermostat apart on wall and joined wires and it still won't work but there is power on it because i can see blue spart. Is the basement zolve valve broke??? even if it will work if up hold it manual and pump and valve flow??
    THank you for your time.
Similar Threads: Zone valve
HVAC Heating & Cooling Taco zone valve coming loose Dec 16, 2015
HVAC Heating & Cooling Adding Zone valves to Honeywell Aquastat L8148J Mar 6, 2014
HVAC Heating & Cooling Wiring 4-6 Zone Valves into Argo 20KW Electric Boiler. Do I need a control box ? Nov 8, 2013
HVAC Heating & Cooling Problem with Honeywell hydronic zone valve--replacement the only option? Jan 28, 2013
HVAC Heating & Cooling Convert from zone valve to zone pumps Jan 2, 2013
