York Furnace and A/C 2002 - wire cut.
Discussion in 'HVAC Heating & Cooling' started by Tim429, Jul 15, 2008.
  1. Tim429
    Tim429 New Member
    Apr 14, 2008
    I accidentally cut the wire from my thermostat to my furnace and after repairing the wire the furnace and a/c will still not work. Any ideas on what the problem could be? Thanks.
  2. jadnashua
    You may have overheated and ruined the 24vac transformer. This is the control voltage that energizes the controls of the system. Assuming you made good splices, verify you have 24vac available. An electronic thermostat might not have been happy, either depending on how the cut happened (it could have shorted things together). Note, many electronic thermostats have batteries in them...check yours to verify they are still good. On some, the batteries are only for backup, on others, they actually run the thing. A mechanical thermostat won't have that problem.
  4. jimbo
    jimbo Plumber
    You might have tripped the circuit breaker, and there may be a small fuse on a control board inside the furnace.
Similar Threads: York Furnace
HVAC Heating & Cooling 7 red flashes - York furnace Feb 17, 2015
HVAC Heating & Cooling Tell me about York furnace! Jun 8, 2010
HVAC Heating & Cooling Malfunctioning York Gas Furnace? Dec 7, 2009
HVAC Heating & Cooling Question regarding diagnostic code on recently installed York GY9 series gas furnace Feb 9, 2009
HVAC Heating & Cooling Comments or issues with York A/C units? Jul 15, 2013
