Wisbro PEX compatable with Manabloc?
bigwooo
BCS Mexico
I'm designing the plumbing for our new home. I would like to use PEX with the Vanguard Manabloc home run system. I have a good local supplier for Wisbro pipe and fittings, but none for Viega. I remember reading something about the compatability between wisbro pipe and the manabloc but can't seem to find it anywhere.
Can Wisbro pipe be connected to the Manabloc somehow?
Are wisbro fittings good quality fittings?
If the wisbro won't work with the manabloc, I have no local suppliers for Viega products. Any internet supplier suggestions?
Thanks.
jdgoodman
Journeyman Plumber
Seattle
Yes wirsbo does have good fittings in my opinion and they come in plastic or brass. They also produce manifolds, I would stick to the same brand the whole way through.
Master Plumber Mark
www.weilhammerplumbing.com
dont mix them
they have great black plastic fittings that
im my opinioni are better than useing brass...
I would not mix them myself,
---but I assume that the
pipe size has got to be exactly the same for both... I dont know why you cant,, but that would be your gamble....
I am buying 2 , 8 port copper manifold with
pre-installed stops to do a home next week..
they can be ordered up to 12 ports
bigwooo
BCS Mexico
Thank you,
For some reason I was fixated on the Manabloc and never researched the Wisbro manifolds. I'll just stick to Wisbro all the way through.
My supplier stated that in California, where I live, there is a new law that won't allow any lead in the fittings. Apparently the Wisbro brass fittings used to have a small amount of lead in them. He says there is a huge difference in quality of the fittings he bought before the law, and those purchased after. He says the new ones don't appear to be as heavy or durable.
Has anyone experienced this? Is this company wide, or only in California?
If it's only California, I may be looking to order the fittings from another state.
