Winterize lake water intake to cottage
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by lhartl, Oct 1, 2009.
  1. lhartl
    lhartl New Member
    Feb 5, 2007
    Homemaker
    Coquitlam, British Columbia, Canada
    We have a water pump, filter and bladder tank in our utility room and about 100 feet of 1 1/4" flexible pipe from the cottage to the lakeshore, ending with a footvalve, about fifty feet from the lakeshore in about 25 feet of water.
    The pipe is exposed under the cottage about four feet, then it is buried all the way to the lake. Each fall, after draining all of the water inside the cottage, we pull up the foot valve, remove it and drain the water from this pipe.
    This year, we hoped to install a Hanflo Quick Disconnect valve closer to the beach (we had estimated/hoped for 3 feet of water) so that we could drain the water without the need for a boat - allowing us to start/drain the water systems for an occasional weekend visit before the snow arrives.
    However, we realize now that the pipe is buried in the water and even with the low water of the fall, access to the pipe in the water is at least five feet deep. I am doubtful that the water will go down much further.
    Our cottage sees -20 degrees in the winter and six feet of snow. We are looking for a solution that allows us to drain the systems easily (i.e. no boat and not get wet) and does not put the pipes at risk of breaking.
    thanks for your help,
    Linda
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Keep on doing what you are doing. It's a Pita but it works and will always work.
  4. lhartl
    lhartl New Member
    Feb 5, 2007
    Homemaker
    What is a Pita? It works but then I can't use the cottage again until the boat is available in the spring! I would like a solution to enable me to drain the pipe after close-up but before the snow comes. ideas ???
  5. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Pita = Pain in the A*&. I'm not sure from what you have described that there is an easier way to go about the problem.
Similar Threads: Winterize lake
Pumps and Tanks Well Forum & Blog. Water is life. Should I Winterize my deep well pump? Aug 20, 2016
Pumps and Tanks Well Forum & Blog. Water is life. winterize bladder tank Nov 8, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Can I “winterize†the charged water feed lines in my cottage with RV anti-freeze? Feb 18, 2010
Pumps and Tanks Well Forum & Blog. Water is life. May I leave my lake water pressure tank out over winter? Oct 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Keep water line from lake from freezing/ Sep 7, 2016
