Greetings. I'm a DIY'er and am working on building an off-grid home. Because of affordability, I'm going to need to do all this work on my own.
So familiarizing with the 2018 IRC, I've done my best to follow it and would like to see if someone experienced can check me off here on this system for a single bathroom and kitchen. I'm also wondering for one, if I can use an air admittance valve in the two circumstances as you'll see in the attached images. My 2" vent to roof is going to be a little too far from the lavatory sink and tub, so I'm wanting to use an AAV for that portion of the system. It code states so long as there's one rooftop vent, it should be okay to do this? The main branch is 3"diameter, the laundry drain and vent stack is 2", and all other 1.5". All advice and comments appreciated. Thank You
