Will a nicked copper pipe ever leak?
yakman
Hello,
If one were to nick the hot water copper pipe with a hand saw while removing the surrounding stud, :eek: and it does not leak now, does that mean forever no leak?
Thanks,
Doug
inspectorgene
I ain't no plumber, but I wouldn't bet on it-depending on the size of the nick, of course.
I would [at least] put a pipe repair band on it as a precaution before sealing the wall back up.
YMMV
Hello,
Thanks,
Doug
yakman
pipe repair band? Hadn't seen one of those before. Google search found a 1/2" x 3" stainless steel band with a neoprene liner and tightening bolt attached to it. Is this what you're talking about?
I suppose the neoprene sleeve would support the nicked wall.
The best way to solve this is probably to cut on the nicked surface and couple right there with a soldered joint.
Is a nicked no leak pipe stronger than a coupled soldered pipe?:confused:
Thanks,
Doug
Master Plumber Mark
www.weilhammerplumbing.com
patch it with solder
you can cut it if you so wish and put a sharkbite or coupling
in the line
One easy way is to
drain the pipes and simply put a patch of
solder over nick in the pipe
you can actually repair a frozen split copper pipe
bending it back together and soldering it shut....
so it is no big deal to just put a thick layer of solder
over the place you are worried about...
