Why does my shower water temperature gradually get cooler?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by rhliberman, Jan 29, 2008.
  1. rhliberman
    rhliberman New Member
    Oct 6, 2005
    When I set the water temperature before stepping into the shower, within a minute or so I can feel the water getting cooler. I have to continuously keep increasing the hot water.
    I have plenty of hot water, the temperature just will not stay constant.
    This only occurs in the master bathroom, not the others.
    Thanks
  2. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    What brand is the valve? Do the other fixtures in the bathroom have problems?
  4. fidodie
    fidodie New Member
    Jan 22, 2008
    computers
    new jersey
    your expansion tank is in a warm area, and the water coming from the water main is colder and mixing with it. the result is the cold water gets colder. This assumes you have a well, and expansion tank and the well is kicking in.
    other possibility is your dip tube on your water heater is broken off.
    cold water gets into the top of your water heater, instead of the bottom...here's a visual.
    [​IMG]
    it directs cold to the bottom, and pushes hot out the top...
    condo/apartment or home? well or city service?
  5. rhliberman
    Oct 6, 2005
    I replaced the compression valves myself a couple of years ago. I picked up the valves from a local plumbing supplier. Knowing me, I must have done something wrong - so, it could be the valves?
  6. rhliberman
    Oct 6, 2005
    Thanks, but since this only happens in the master bathroom I don't think it's a water heater problem.
  7. fidodie
    fidodie New Member
    Jan 22, 2008
    computers
    new jersey
    My Bad - missed that last line......
Similar Threads: does shower
Plumbing Forum, Professional & DIY Advice Move shower drain to other side of joist. Does it meet code? Apr 11, 2016
Plumbing Forum, Professional & DIY Advice Elevated shower drained fine now it doesn't. Help I stink! Feb 21, 2016
Plumbing Forum, Professional & DIY Advice Symmons Temptrol, Does shower cartridge/diverter need to be replaced? Jan 27, 2016
Plumbing Forum, Professional & DIY Advice Kohler Bancroft shower valve "doesn't fit" in newly built bath Apr 29, 2015
Plumbing Forum, Professional & DIY Advice Why does my cold water turn warm? Delta Shower Valve Mar 28, 2015
