Whole house shutoff/leak detection system
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Big Teddy, Nov 22, 2013.
  1. Big Teddy
    Big Teddy New Member
    Nov 22, 2013
    Amherst NH
    I'm looking for a whole house shutoff/leak detection system. Anyone have any suggestions for this? I have a well water supply and I have seen a few types of systems for this. Most systems seem to use a shutoff motorized ball valve that just doesn't make sense to me because of the placement in a well system. If you place it between the pump and the pressure switch then when a leak is detected it will close the supply from the pump but the pump will still run because the pressure switch will demand water due to the leak. It will either burn out the pump or rupture a pipe in the well due to over pressure. If you mount it after the pressure switch, any leak upstream (Tank, Manifold, Etc) will just keep leaking because the pressure switch will keep demand for water because of the low pressure created due to the leak. Make sense?
    Thanks
    Ted
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
Similar Threads: Whole house
Pumps and Tanks Well Forum & Blog. Water is life. Well to pressure tank to whole house filter to Jun 26, 2016
Pumps and Tanks Well Forum & Blog. Water is life. whole house filter, AFTER WellTroll tank? Jan 8, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Whole house filtration for well water question May 4, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Lakos Sub-K vs. SandMaster PLUS for sand/sediment mitigation (whole house+irrigation) Dec 15, 2013
Pumps and Tanks Well Forum & Blog. Water is life. How Much More Pressure Will I Get To My Outside Bibs If I Bypass My Whole House Filte Jun 25, 2013
