whole house filter, AFTER WellTroll tank?
Jeremytl
Scientist
durham, nc
I need to install a whole house filter. Lately there has been a lot of reddish sediment. Should I install the filter before or after the bladder tank? I have a Gould pump under house going to Well Troll tank, then everywhere else. Where should I put the whole house filter?
Filter after the pressure tank. The pressure switch goes at the pressure tank. If you had a filter before, it could clog and have the pump on continuously.
Jeremytl
Scientist
durham, nc
my setup..
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
It looks like the sense line for the switch is tapped off the pump so a filter between the pump and the tank would bounce your switch.
Jeremytl
Scientist
durham, nc
I think I am following you, I need a little translating though. "Bouncing" the switch is bad, right? Basically, the whole house filter needs to be AFTER the pump, right?
