Which Well Pump
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by dm0978, Aug 31, 2013.
  1. dm0978
    dm0978 New Member
    Aug 31, 2013
    Altus, OK
    I have a submersible well pump feeding a 1500 underground storage tank. I now want to install a pump which will draw from the storage tank and feed an undergound sprinkler system. Should I buy a conventional jet pump with a pressure switch and pressure tank, or an electronically controlled pump, which requires no pressure switch or tank?
  2. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    I'd buy a submersible pump, install it in the tank then install a Cycle Stop Valves "Pside-kick" kit. The Pside-kick comes with a small tank, cycle stop valve, a pressure switch and everything you need. http://www.cyclestopvalves.com/st-viewcat.php?cid=26.
    Stay away from VFD pumps, they are expensive and troublesome.
  4. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Conventional jet pumps are not too shabby in this application. Their 'sweet spot' is right in the operating window of common lawn sprinkler heads. A baby pressure tank combines with the pressure switch already on the jet pump to give you a complete supply for a sprinkler system.
  5. dm0978
    dm0978 New Member
    Aug 31, 2013
    Altus, OK
    I've looked at the Pside-kick. I think I understand it, but I'm not sure. How is it different than a pressure tank, pressure switch, and water pressure regulator combination.
  6. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Jet pumps have a more pronounced curve and as a result the loops are easier to tune to match the curve. A sub would be more energy efficient if properly matched but they may be harder to match due to their curve.
    A CSV would allow for a wider range of GPM and save having to tune the loops. When used with a CSV, a sub that does not float each impeller would likely draw less power than one that does.
Similar Threads: Pump
Pumps and Tanks Well Forum & Blog. Water is life. Flat or twisted cable for deep well pump Today at 8:25 AM
Pumps and Tanks Well Forum & Blog. Water is life. Well pump replacement and bad advice Tuesday at 4:05 PM
Pumps and Tanks Well Forum & Blog. Water is life. Well pump issues Tuesday at 7:09 AM
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Saturday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Well pump varies, Please help I'm clueless Feb 15, 2017
