Where to add bleed valve?
Discussion in 'HVAC Heating & Cooling' started by dripdrip, Oct 18, 2009.
  1. dripdrip
    dripdrip New Member
    Nov 22, 2008
    NE
    Hi. My mom has a rough old house, and she didn't have enough heat on the first floor, so I added 3 new radiators by running 3/4 pex on the ceiling. Now the problem is I realized there is probably a lot of air in that pex up high, since it keeps coming down to the rad and then back up and down to the next one.
    Should I add two boiler drains to the loop in the cellar and try and blow the air out?
    Or maybe just one boiler drain and try and use the bleeder valves on the rads to let air/water out?
    Or just let the air sit and keep using only the bleeder valves on the rads?
    DD
Similar Threads: Where bleed
HVAC Heating & Cooling Where can I buy a radiator bleed key? Oct 25, 2007
HVAC Heating & Cooling Square to Round Duct Transition - Cannot find anywhere?? Today at 6:54 AM
HVAC Heating & Cooling ac/heat pump/e heat-unit-where should my main air duct be placed Jun 6, 2011
HVAC Heating & Cooling Ducane furnace still not lighting. No power where ignitor connects to smart valve. Oct 4, 2010
HVAC Heating & Cooling DIY HVAC Equip. Where? Nov 18, 2009
