Where is the bl....... pump specialist when you need one.
Discussion in 'Pumps and Tanks Well Forum & Blog' started by padd_y17, Jan 6, 2009.
  1. padd_y17
    padd_y17 New Member
    Jan 6, 2009
    I have the pump in bits the old man is due home soon and he is going to do his nana when he sees it. all i have to do is get the motor off the wet side and oil the bearings.........pls annnnnnnnnnyyyyyyyyyooooonnnnnnnnnneeeeeee ooouuuuuuuuuuuttttttt ttttttttthhhhhhhhhhhhhhheeeeeeeeeeeeeerrrrrrrrrrrrrrrrreeeeeeeeeee??????????????
  2. Gary Slusser
    Retired
    What type pump is it, jet or submersible? My guess is a jet because there aren't bearings in a sub. What brand? Describe what you've done so far.
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Most motor bearings (good motors that is) are factory greased not oiled. Oil will not last long at all on them and for all the work involved in taking the pump and motor apart, new bearings would be a far easier solution. Most motors use 6203 bearings front and back and they are the least expensive bearing there is.
    bob...
Similar Threads: Where pump
Pumps and Tanks Well Forum & Blog Wires pulled out of deep well pump, don't know where they go Nov 22, 2014
Pumps and Tanks Well Forum & Blog pump start relay - where to get just the relay May 21, 2014
Pumps and Tanks Well Forum & Blog recently replaced pump seams to be leaking somewhere? Aug 11, 2013
Pumps and Tanks Well Forum & Blog Help! Where to install pump pressure switch? Oct 5, 2012
Pumps and Tanks Well Forum & Blog Submersible pump mystery - where to go? Sep 8, 2011
