Where/how to attaach safety cable on Well Seal?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by xlr8tion, Apr 19, 2012.
  1. xlr8tion
    xlr8tion P.E. (Professional Engineer)
    Oct 1, 2011
    SC
    OK...I know you guys don't use safety cables/cable guides and etc.....
    Hypothetically...where does the safety cable attach to the pump and how do you attach it to the bottom of the well seal(I have a 4" splt simmons).
    I know these can fall back into the pump; but if my South Carolina installer drops the pump its gone in a 1000' foot deep aquifer and Johnny Reb-neck is not gonna do anything except say "whoops"..
    Thanks...FWIW the pump(Grundfos 16 GPM two wire 1.5 HP 230 V) is going in tomorrow.
    Thanks......
    Greg
  2. xlr8tion
    Oct 1, 2011
    SC
    Bump to the top....
    Somebody help a brother out..LOL....
    Pump guy arriving in 6 hours...
    Greg
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    That type of pump usually has a cut out at the top are you can attach the rope. But you can also attached at the intake.
  5. xlr8tion
    Oct 1, 2011
    SC
    What about at the Well seal? Oh..and is 3M Temflex ggod for taping 2 Drop pipe?
    Thanks.....I don't know folks just don't use high quality zip ties? Seems more resilient than rubber tape.
    Greg
    PS...I am putting a 1.25x3" 316 SS nipple into the top of the pump so they don't overthread the SCH 80 PVC into the pumps Check valve. I am using a 316 coupling from the nipple to the drop pipe to eliminate an dielectric corrosion. All SCH 80 dp will use 316 SS couplings as this is a potable H20 supply and the galvanized steel ones I saw were of horrible cast quality(Made in China)
  6. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
    The rope is extra and may not be needed. Many pumps do not have a rope attached. The wire and the water pipe are used to hold the pump. The rope does help with lowering the pump in the well if you are doing it by hand, the pump is going to be set deep and it's heavy. You can tie the rope to a tree if needed to take a break etc. Once the pump is in place the rope is loose. It comes up out through a hole etc and tie it to the casing etc so it does not fall in.
