grahamW
I've now located the waste line under my slab.
Above the concrete, all the plumbing waste/vent lines are ABS, while below ground they are green/white PVC. My plan is to wye into the 15" long section of 4" green PVC (photos below) using no-hub couplings for my new floor and laundry drains. I'll be using a single 3" pipe to serve both. A rough sketch of all this was previously posted and I'd still welcome feedback.
My question is: At what point should I switch from PVC to black ABS? Is there a reason that PVC is used below the slab?
NB: I found a chunk of unused, busted green PVC pipe which is marked in the photos. It must have been discarded when they did the install and then filled over. Annoyingly, it looks more functional in the photos than it is.
