When they come to replace my panel...
Ian Gills
Senior Robin Hood Guy
USA
...one day how easy will it be for them to connect the circuits up to the new one?
Do they often have to extend circuits by using lots of metal boxes?
I want to try and avoid that so always put some slack in any new wiring I do near the panel. Is that a good idea?
I found a couple of wing nuts in my panel splicing wires to extend them. That's not allowed is it?
Do you like the way I speak in questions?
Speedy Petey
Licensed Electrical Contractor
NY State, USA
1) Hopefully for them it will be easy.
2) Not usually.
3) Yes, but not too much.
4) It certainly is. It's better than a bunch of boxes over your panel.
5) Do you like it?
Ian Gills
USA
Thanks Petey.
I feel better now.
Can't wait to get the new panel installed with a new riser, once all my new little bits of wiring are done.
The quote I got for this was a year or so ago. I hope the price has not changed that much. It was only a few thousand which I think is very reasonable for a service upgrade.
I wish I could do it myself, but this is just one of those where it is absolutely impossible to DIY safely and legally.
Scuba_Dave
Extreme DIY Homeowner
South of Boston, MA
holidaves.com
100a or 200a ?
1st thing I did with my 200a is install a 100a sub
They installed my 200a literally right beside my old 200a (corroded)
Some of the circuits just need to be run down the next joist to free up some length
Alectrician
DIY Senior Member
How easy will it be for them to connect the circuits up to the new one?
I do it for a living and there is generally nothing easy about it.
I minimize jboxes as much as possible.
To a certain extent, more is better.
Sure it is.
That's kind of the point here.
Billy_Bob
So far as projects like this go, there are "good days", "so so days", and "bad days"!
Sometimes there are "unforeseen problems". You start pulling things apart and find a "problem". And then you spend a lot of extra time fixing that problem.
Like maybe you have a wood outside wall, pull the old panel off and there is a bunch of dry rot there which needs to be fixed before proceeding.
Or you suddenly realize you need one certain part which you don't have, then need to go to the shop/store and get that. (I live in a rural area, so that shoots 3 hours out of my day!)
But sometimes everything goes smoothly, no problems, you have all the parts, everything done quicker than you thought it would take.
Be sure to offer the electrician water or soda pop. And tell him where the restroom is if he needs to use it. He will instantly like you!
nickdel
I've done a 200a service in 11 hours, and I've done it in 4. It really does depend on how things turn out once you're on site and start pulling things apart.
nickdel
A long time ago an inspector told me, "No wire nuts in the panel. It is not a junction box". Times may have changed.
I'm pretty sure that splices are only supposed to be made in a panel if there is a specific area in the panel designated for that purpose. Your standard main residential panel doesn't have such a space.
Ian Gills
USA
It's a 100 amp panel. I am hoping they will take it off and replace with a 200 amp and replace the riser and meter box.
Here's some more questions.
I have a Square D QO panel. Will they just replace it with another Square D QO panel and use the existing breakers (if those breakers are to code)?
Will they expect me to hang from the live wire while they disconnect the riser? I weigh over 250 pounds and doubt the hot wire which is suspended about 20 feet up could take my weight.
Speedy Petey
NY State, USA
Incorrect. "Pretty sure" does not cut it.
Read the section pertaining to this and you'll see.
It says as long as there is space for the purpose. Not as long as there is a dedicated or designated space.
Scuba_Dave
South of Boston, MA
holidaves.com
Yes they should replace it with a Square D panel & re-use the breakers
Might want to verify with them that it is what you WANT them to do
Is your service wire rated for 200a?
If it's not I'd still put in a 200a panel & feed it with 100a for now
If the meter has to be replaced I'd also make sure it is capable of handling 200a
What work have you requested they do?
Make sure you have everything in writing so you know what to expect & they know what you want :)
I had a generator running for an hour or so just to keep my fish tank running
Ian Gills
USA
Thanks Dave. They are a trusted local firm so I trust them.
They'll be no "I only asked for an addition but you built a bloody house on the side of house", believe me.
My service is 200 amps but the riser is deteriorating and the meter case is only rated for 100 amps. The panel is also 100 amps.
What can I expect to see during the time they fit all this and the inspector/electricity company do their thing? Obviously the electrician will not be able to change over the new riser they fit will they?
Scuba_Dave
South of Boston, MA
holidaves.com
I wasn't home when they did mine
But everythingw as arranged in advance between Electrician, Inspector & POCO for timing
Since he was able to connect the new panel in advance that cut down on the time without power
Basically the new Meter base was in & wired to the new panel
New wire (had it buried) was run & hanging at the pole
Electrician shut everything down & moved circuits over
POCO came & connected at the pole & installed the new meter
Inspector was there within the hour to Inspect
All OK'd & it was powered up
I think in total power was out for maybe 2-3 hours tops
POCO as fas as I know has to make the final connections
All went as planned - no surprises or problems
Ian Gills
USA
hanks Dave. I guess you'll be upgrading again soon too. I doubt 200 amps will be enough for your mansion when its finished. Perhaps you could fire up the old 200 amp panel again and get a second service?
Scuba Dave's house and addition cannot be seen when you come down the road, but they sure as heck can be seen from space.
T
Alectrician
DIY Senior Member
Times haven't changed. There are still inspectors that pull rules out of their southernmost orifices.
Scuba_Dave
South of Boston, MA
holidaves.com
Actually the old 200a will be going in the addition as a 100a sub :D
I'm competing with the Great Wall of China
You know that Christmas movie (Deck the Halls) where Danny DeVito was trying to light up his house with enough Christmas lites to be seen from space?
That was based on my house
Here in a nite shot you can see my house lighting up MA on the east coast south of Boston:
nickdel
Well, if "pretty sure" doesn't cut it, neither does, "as long as there is a space," not when the code is very specific. So let's be more specific. "Space for the purpose" means that the space for wires in the panel cannot be filled by conductors to more than 40% of the cross-sectional area at any cross-section of this "space." And, further, that the conductors, splices and taps cannot fill more than 75% of this cross-sectional "space."
Now, I'm pretty sure, Speedy Petey, that no electrician has ever walked into someone's house, measured out and calculated the available cross-sectional area inside a panel, then determined the total cross-sectional area of the conductors, then made sure that the cross-sectional area of the conductors was within 40% of the total cross-sectional area of the panel, then determined the cross-sectional area of all the splices and taps, added that number to the total cross-sectional area of the conductors, and then made sure that this new total was within 75% of the total cross-sectional area available in the panel. (At least not in this country. I heard that the electricians in England are more clever than us, though.)
So maybe it's just easier to say don't make splices in a panel.
Cross-sectional!
