What would magnetize a receptacle?
Discussion in 'Electrical Forum discussion & Blog' started by Taylor, Oct 5, 2008.
  1. Taylor
    Taylor New Member
    Mar 9, 2005
    Northern Joisey
    Removed a box from a circuit yesterday. Today, the circuit breaker blows every time the microwave (on the circuit) is turned on. Has worked fine beforehand. In switching the microwave over to another circuit, noticed that the receptacle for the microwave appears to be magnetized. Is this a clue to what is going on? Are hot and neutral switched somewhere? All i did yesterday is remove wires.
    BTW not a single box in this house is grounded.
  2. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Not really sure what you did, but if it worked all the time until you touched something, I think I know what the problem is.
  4. Taylor
    Taylor New Member
    Mar 9, 2005
    Northern Joisey
    :confused:
    I removed a box and the corresponding wires in a junction box that had both the removed box and the microwave receptacle downstream (separate streams).
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    What would magnetize a receptacle? Nothing
  6. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    Plastic magnet?
  7. Southern Man
    Southern Man DIY Hillbilly
    Jun 27, 2008
    North Carolina
    I grew up in an old house like this. I'm guessing that you have plaster walls with metal lathe as well. I'm also guessing that you have a hot wire connecting to the wall somewhere. Electrical flow through iron (the steel lathe) will make a magnet.
    You need to call an electrician and find out where the leak is.
  8. Taylor
    Taylor New Member
    Mar 9, 2005
    Northern Joisey
    Plaster walls but.....
    ....wood lathe.
    Sounds like people do not see a connection with the (observed) magnetization of the receptacle and the microwave blowing the circuits. Just realized that the gas dryer was running downstairs on the same circuit as the microwave, maybe that was the source of the circuit breaker tripping. Even gas-fired, it needs juice to turn the drum.
  9. Southern Man
    Jun 27, 2008
    North Carolina
    Old homes tend to have a mixed bag of circuits. There could be a lot going on. The magnetic effect still points to a current leak somewhere. Old plaster is reinforced with all kinds of materials (my sister discovered horse hair in hers), and a lot of things can carry electricity. You should shut off all your appliances and lights, and see if the area is still magnetic. Also look at your meter and see if its still moving. If it is, then turn off all breakers until it stops moving, and find out which one is using electricity without anything turned on.
  10. hj
    outlet
    How do you "observe" the magnetization?
Similar Threads: magnetize receptacle
Electrical Forum discussion & Blog Light Switch wired to receptacle. Can I use to add recessed lights? Mar 19, 2017
Electrical Forum discussion & Blog Wiring Split 15 & 20 amp circuits on same receptacle Feb 22, 2017
Electrical Forum discussion & Blog 15 amp arc fault receptacles on 20 amp circuits? Sep 5, 2016
Electrical Forum discussion & Blog 240v receptacle conversion Apr 7, 2016
Electrical Forum discussion & Blog How does the Receptacle , the wiring, CB and code Relate? Mar 18, 2016
