What size PEX to use....
Nick--L
New York
I am going to be replacing old copper lines in a home. I currently have a 1" line entering the home and within a few feet, it gets reduced to 1/2. I will be installing PEX manifolds and am wondering if there is an advantage to maintain the 1" line to the input to the manifold. All of the manifolds I can find, are 1" copper with 3/4 pex inputs. If you have a 3/4 " pex fitting on a manifod, is there an advantage to use 1" Pex to that fitting, or did any "volume" advantage disappear with the reduction to the 3/4" input. Thanks for your help
A short length pipe or fitting reduction doesn't equate to a long length of the smaller pipe because of the venture effect...the fluid (air/water/whatever) will speed up through a short reduction and then return to it's 'normal' speed while only inducing a slight pressure loss. The cross sectional area ratio of 1":0.75" is 1.96:0.44, or over 4x as much area, and that relates to its volume capacity. 3/4" pex is smaller than 3/4" copper. Now, whether you'd need that volume, I don't know, but if you went with 1" pex and converted to 3/4" at the manifold, you'd minimize any friction losses along the way, and maximize your working pressure (not the static pressure, which would always stay the same). ON the hot side, it would also increase the time it would take to get hot water since the pipe would hold more that could have cooled off since the last use. You might want to consider a hot water recycling system...it can save wasting water and increase your overall comfort. If you insulate the pipes or tubing well, it is not a significant energy user.
Nick--L
New York
great answer, just what I was looking for......
