What pressure for air testing copper?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by seaneys, Feb 10, 2008.
  1. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    Hello,
    I'd like to pressure test my vertical spa installation (lots of fittings). It has held 40 PSI for 4 hours.
    What is the recommended air pressure and set time for air testing copper? The valves are installed. I did not want to risk over pressurizing the valves.
    Thanks,
    Steve
  2. RioHyde
    RioHyde Plumber
    Sep 24, 2004
    Cincinnati, Ohio
    100psi for 30 minutes here
  4. hj
    test
    The valves are rated for 150 psi working pressure and no common compressor is allowed to exceed about 125 psi, so you couldn't damage the valves.
  5. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    Thanks a ton! The max pressure was exactly what I was just scratching my head about.
Similar Threads: pressure testing
Plumbing Forum, Professional & DIY Advice Air pressure testing water lines Nov 10, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing copper pipes Sep 24, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing PEX lines leading away from a ManaBloc? Feb 23, 2016
Plumbing Forum, Professional & DIY Advice Pressure testing copper pipe add-on Dec 27, 2015
Plumbing Forum, Professional & DIY Advice Pressure Testing Shower Installation Apr 30, 2015
