What is this and what to do with old fireplace?
Discussion in 'Remodel Forum & Blog' started by Lakee911, Feb 26, 2006.
  1. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    I've got a house from the 20's with a "decorative" fireplace. It's approx 26in x 27in x 8.5in (W x H x D). It has a narrow throat and has insolation stuffed in it. The harth is ceramic tile. There is a capped off natural gas pipe in the center of the harth approx 4in from the back wall. The chimney has three flues. One is being used for the furnace and HWH. One I assume goes to the fireplace and tthe other, I dunno. I'd like to do something about this. Obvously too small to throw some wood in and burn a fire. Did it have an insert? Why aren't they used anymore? What can I put in to make some heat? Is the back a false wall bricked up that I can remove?
    Thanks,
    Jason
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I would explore a gas insert. A traditional fireplace in very impractical given the fact that they lose more heat than they provide and the high cost of wood in many places. A gas insert will give you the atmosphere of a real fire and provide some heat, but without the drawbacks of a traditional fireplace.
  4. sulconst2
    sulconst2 New Member
    Jul 11, 2005
    remodeler
    old bridge nj
    sounds like a wood burner converted to gas. is there a flue? doesn't sound like it if it has insulation stuffed up. is there a shut-off for the gas? you could by a gas log kit. and a flue that attaches to the top of chimney and works off a chain. that way you don't get the cold coming down to top of fireplace. maybe get an estimate so you can pick his brain. ;)
  5. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    Sounds like an old fireplace for a common coalstove insert from the '20's, because 8.5" depth is most likely too shallow for a former woodburner.
    I highly doubt that the flue is safe enough as-is for anything but gas firelogs now, as Gary said.
    There are different types of firelog units...some are primarily decorative, some are ventless, and some need a small amount of venting. Some have a blower for getting max heating benefits. Some have electronic ignition. Some have a pilot light. Some have a remote control unit. All need a carbon monoxide alarm on the ceiling of the room they're in (as do all fireplaces).
    You just need to choose the type that you want and install it. Make sure that you choose one for natural gas and not one for propane gas. There is a difference. There are a lot of options, and you can get a lot of energy-efficient heat from a good one.
    Good Luck!
    Mike
  6. Lakee911
    Aug 23, 2005
    Columbus, OH
    Thanks for the info. Looks like their might be a flue. If I remove the insulation, I'll be able to see. I'm kind of scared of what critters or debris might fall out if I pull it out. Heh
    Do you think there is a chance that they walled up the existing fireplace which is why mine is so shallow (8.5in)? Ok to drill an inspection hole in the back?
    I found some "coal basket" inserts online, but I don't know if I really like the look of them. They're vented too and I'd like to go ventless. :( Fake wood burning ventless inserts I think need more clearance.
    Thanks for the help,
    Jason
  7. finnegan
    finnegan New Member
    Aug 16, 2005
    CT
    I would have a fireplace/chimney guy inspect it before you do anything. They flue might be in bad shape.
  8. prashster
    prashster New Member
    Dec 7, 2005
    Fireplaces - wood burning and vented gas fp's SUCK at heating - literally.. You have to vent, to release the CO. But all the heat goes with it. Conventional fp's can suck the heat out of yr house, making other rooms colder.
    You should get a ventless gas unit. These units use filters (charcoal, etc) to remove CO, but recirculate the heat. It's the more efficient, and easier to install bkz you don't have to deal as extensively with your flue. Have an experienced installer put it in, so they'll deal with your flue the right way; though.
    The fireplace still has to have a source for combustion air, though. If it uses the house air, then the house has to get replacement air from the cracks around yr windows/doors/attic. This gives drafts, making the house seem even colder. Newer homes are tighter and have to have external air intakes (ducts directly to the outside). Like high efficiency furnaces, this relieves drafts in the rest of the house, but if the installer doesn't seal that external duct properly (darn my big box builder!!!), you'll get drafts around the FP when it's not in use. If your ventless system requires an external air intake (the better ones do), make darn sure that your installer provides a mechanism for shutting and sealing it between uses.
    Arguably, since fp's are only used a fraction of the time, more thought and care should be given to how it functions when OFF than when it's actually ON ;)
    FYI, if the back of your FP is a solid piece with faux brick grout lines, it's likely an enclosed firebox and can be ultimately removed. If your chimney from the outside is enclosed in siding and not bricked all the way up, it probably was inserted after, and can be removed. If however, it looks like real brick and the outside is bricked, and yr house is older, there's a good chance it's structural, and you can't really remove it economically. You'd have to insert something over it.
    My advice: seal up the fp, paint a fake one on the wall, and install radiant floor heating ;)
  9. Lakee911
    Aug 23, 2005
    Columbus, OH
    This is true...
    Actually installed one of these for the folks in December. They think it works great. Pile into the fam room and turn the thermostat down. :)
    The back of my firebox is a sold piece of a real bricks and real grout lines. :( It's real. I've got three flues, basement, family and the other I don't know--maybe a FP on second floor. Not sure. Chimney supports the center of the house.
    Yes...I would get that for asking about this on a plumbing site. Hard to roast marshmellows on that radiant floor heating though. :D
    Thanks for the advice.
    Jason
Similar Threads: fireplace
Remodel Forum & Blog How much of the old fireplace can I remove? Aug 19, 2013
Remodel Forum & Blog Wanting a flat panel television above the fireplace May 31, 2012
Remodel Forum & Blog update fireplace Nov 15, 2010
Remodel Forum & Blog Decorative imitation fireplace using hot water for heat Sep 24, 2010
Remodel Forum & Blog Cord control for over the fireplace TV mounting Apr 25, 2009
